ditching the FMU for larger injectors???
Old Dec 30, 2004 | 02:09 AM
ss#1230's Avatar
hey guys, im thinking of losing my vortech FMU and going to bigger injectors. im running the 6psi pulleys and using everything that came in the vortech kit.....the T-rex fuel pump, FMU, crane ignition w/boost retard etc...
any suggestions on the injector size, brand or anything related to the subject is greatly appreciated.
the reason for doing the change is because the car has been tuned but still runs rich and im already going to be changing the plugs after just a few hundred miles after the new supercharger install.....and that just aint gonna fly with me.....
thanks guys!
Old Dec 30, 2004 | 03:33 AM
97WS6SCharged's Avatar
Re: ditching the FMU for larger injectors???
Most people run 42# injectors. Alot of people use FMS injectors.
Old Dec 30, 2004 | 01:00 PM
ss#1230's Avatar
there is a guy selling 36lb injectors for 200 shipped. wouldnt 36lb be enough. i dont plan on adding any more horses for a long time.
42 seems like a bit too much?
Old Dec 30, 2004 | 08:08 PM
OBE1 95Z28's Avatar
I went the 36# route based on my first tuner's recommendation and they're maxed out (running 10# of intercooled boost). I wish I would have gone the 42# route. My new tuner, Jeff Creech, says the 42# injectors are easy to tune.
Old Dec 30, 2004 | 10:15 PM
ss#1230's Avatar
im only running 5-6psi with aftercooler and im not going to be upgrading anytime soon.
thanks for the info guys! keep it coming!
Old Dec 31, 2004 | 06:15 PM
Boosted_Z28's Avatar
When choosing injector sizes usually bigger IS better as the PCM is tuned accordingly. A 42 lb/hr injector can be tuned to work just fine on a stock LT1 (just not necessary). The 42 lb/hr injector seems to be the size of choice when upgrading due to a c.i. increase or a boost requirement. Running a smaller P/W (within reason) is always recommened. The cost is usually the same for most of the common sizes of injectors.
Old Dec 31, 2004 | 11:35 PM
ss#1230's Avatar
so if i come across 36lb injectors for sale cheap would it be okay to run them since im not going to be doing any more up grades?
thanks guys
Old Jan 1, 2005 | 01:57 PM
OBE1 95Z28's Avatar
The 42# injectors don't have any downsides and leave you room to add power later. If I had a nickle for every guy who stated "no more upgrades"!
13qtr
Oct 28, 2016 08:11 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
95craz28
11
Sep 12, 2015 07:47 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
