'93 t56 to '94 t56 swap question
Old Dec 28, 2004 | 10:56 PM
superal's Avatar
I am putting a '94 t56 into my '93 z28. I was wondering if I need to do anything with the skip shift solenoid (93's dont have it) since I have nothing to plug into it. Also wondering if my speedometer is going to work and what I'll need to do to fix it (93's get the speedo reading differently). Is it possible to correct for a differently geared rear the same way that the rest of the 94+ guys do it?
Old Dec 29, 2004 | 11:17 AM
bubba353z's Avatar
Re: '93 t56 to '94 t56 swap question
I have a '95 T-56 in my '92 Z, and the skip-shift plug is empty - no problems. Just leave the solenoid in place and forget about it.
Can't really help you on the speedo - I have a converter box to make the T-56 interface with my speedo. If the 93's and 94's really do have different pickup systems, you may need something similar. I'm sure someone will have the answer on this for you.
Good Luck
Old Dec 29, 2004 | 06:53 PM
superal's Avatar
Thanks for the help. Anybody know about the speedo issue?
Old Jan 1, 2005 | 02:04 PM
961le's Avatar
i put a m29 in my car a few years ago. it is a 96. (manual conversion) when i bought the pigtails for the vss the parts were the same so no problem there. i believe the skipshift only energizes when the computer commands it. so at rest it should not effect you.you will have to get your computer fixed due to the change in ratios in the tranny. pcmforless did mine.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
HectorM52
Jan 31, 2015 07:29 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
nballisru
Dec 14, 2014 05:01 PM
