88 iroc gauge problem
Old Dec 19, 2004 | 08:04 PM
GREAT_WHITE's Avatar
Arrow 88 iroc gauge problem
when i turn my headlights on or park lights on my tach freaks, oil pressure and volt meter go limp and my right inside turn signal glows,,,,i turn the dash lights down to the off position where headlights are on dash is off my gauges work,,,,,replaced the headlight switch, no fix,,, anyone have this problem or heard of it ??? where the hell do i start??? any help would be appreciated
thanks
kris
Old Dec 26, 2004 | 10:44 PM
IROC-T's Avatar
Re: 88 iroc gauge problem
It's time to clean and check all of your under dash grounds. While your doing those might just as well do every ground you can find. Use new star washers where needed and anti corrosive on the others. Sounds like a bad ground in the lighting system and it wants to gound through the tach.
mark0006
Feb 28, 2015 07:12 PM
dale3in98
Feb 14, 2015 12:18 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
