Which year LT1 came with hardened pushrods?
Old Dec 17, 2004 | 12:56 PM
Pasky's Avatar
Is there any other way to tell also? THanks.
Old Dec 17, 2004 | 01:02 PM
teke184's Avatar
Re: Which year LT1 came with hardened pushrods?
didn't think any did...maybe the LT4 in 97...
Old Dec 17, 2004 | 01:05 PM
Dave19yz28's Avatar
'93-'95
not sure how to tell the difference tho
Old Dec 17, 2004 | 04:05 PM
ChickenScreamer94's Avatar
I thought the 93 through 94 had hardened rods, and only some of the 95 LT1 cars?
Old Dec 17, 2004 | 04:09 PM
JBird33's Avatar
I believe you are correct.
Old Dec 17, 2004 | 04:16 PM
94zLT1's Avatar
yes all 93 and 94's had them and some 95's
believe there is a wierd marking or dot on them
Old Dec 17, 2004 | 04:51 PM
Pasky's Avatar
Can anyone describe this marking? I got a 95 and would love to know if mine are hardened.
Old Dec 17, 2004 | 08:21 PM
LT1inaMGB's Avatar
Take a file to one of them. If the teeth just slide across they are hardened. If the teeth dig in and cut, they aren't.
Old Dec 17, 2004 | 08:23 PM
TransAmGT's Avatar
The hardened ones have pink on them..not sure if they are a dot..but i know it has pink on them!
And yes all 93 and 94 cars have them and some 95's!
Old Dec 17, 2004 | 09:15 PM
'94 Bad A Z28's Avatar
'93 and '94
Old Dec 17, 2004 | 11:23 PM
SSmoked's Avatar
Just looked at my 95's. No pink and just 1 dot.
Old Dec 18, 2004 | 12:18 AM
Scotts94z28's Avatar
Yes, my hardened pushrod has pink on it.
Old Dec 18, 2004 | 02:21 AM
SSmoked's Avatar
I have a 94 motor im switching out for a 95, should i put the 94's pushrods in the 95? 94 has 133k miles and 95 only has 58k. Would it be worth it since im not buying new ones atm?
Old Dec 18, 2004 | 05:48 PM
TransAmGT's Avatar
No...you don't need them with a stock motor! That would be way too much trouble!
Old Dec 18, 2004 | 07:04 PM
Pasky's Avatar
Im asking because im wondering if I should replace mine. Only time the strength of the push rod is an issue is when it comes to mis-shifts correct?
