1995 Pontiac TA Dark purple metalic
Old Dec 7, 2004 | 02:40 PM
Ryan94Camaro's Avatar
I need the garage space and have to get rid of my car.
Dark Purple Metalic
T-tops
81,xxx miles
355ci LT1
The engine is a built LT1 with 600miles on it.
Bored .030
eagle steel crank
eagle steel rods
JE/SRP forged pistons
Comp XE 230/236 .544/.555 112LSA cam
Comp pro mag 1.6 rockers
Comp hardened pushrods
SVO 30# injectors
New High pressure oil pump
New oil drive assy.
Heads are milled .030
stock valves
Ports were cleaned up with a sanding roll
Rear end is from a 2002 Camaro SS with 11,000 miles on it.
3.43 gears(no sticky tires have been bolted up to it, not even drag radials)
Intake was port matched to the heads
More performance low mount alt. kit
Mac Mid length headers and y-pipe
2002 SS catback with some $100 quad tips
Boxed in stock panhard bar
Boxed in stock LCA's
Polly busshings on the tranny mount and torque arm mount
Taylor over the valve cover wires
new water pump
The computer was dyno tuned at Total engine airflow for this combo using LT1 edit. The compter still needs to be changed for the 3.43 gears. It is set up for 2.73 gears
AC delete
Heat Delete
P/S Delete
The transmission is a GM rebuilt 4L60E unit that needs to be rebuilt again. The 3 and 4 gear clutch packs are burnt up.
$3500
I REALLY REALLY NEED TO SELL THIS CAR
Old Dec 7, 2004 | 05:08 PM
TRIPLE G's Avatar
Re: 1995 Pontiac TA Dark purple metalic
Can i get some pics of the car. Body, interior, motor.
Thanks
tom.noonen@gmail.com
Old Dec 7, 2004 | 08:28 PM
I will have all the pics you asked for tomorrow afternoon. I e-mailed you a small pic that I had on my comptuer.
Old Dec 8, 2004 | 08:17 AM
CscottsSS's Avatar
pics please calebbender@gmail.com
Old Dec 8, 2004 | 11:30 AM
I will send the pictures to you CscottsSS when I get home from work.
Old Dec 8, 2004 | 06:21 PM
I think I got pics e-mailed to everyone interested. If I missed you, let me know.
BUY MY CAR
Old Dec 11, 2004 | 10:03 AM
SeekinWS6's Avatar
Hey, can i get some pictures of that thing? Thanks formulamotox@comcast.net
Old Dec 12, 2004 | 04:10 PM
Come on people!!! $3500 This is a great bracket car. It ran within 1 hundreth of a second every time down the track. Thats on street tires as well! I MUST SELL THE CAR THIS WEEK!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 12, 2004 | 08:45 PM
Rocks94z28's Avatar
send pics my way too,
What times did it run at the track?
any leaks?
does it have a stall?
pm me your bottom dollar, i might be interested,
Old Dec 12, 2004 | 10:15 PM
I sent you an e-mail to JHrocks311.
Let me know
Old Dec 13, 2004 | 04:48 PM
LPE Z convt's Avatar
Send pics to Lingenz@insightbb.com
Thanks Chris
Old Dec 13, 2004 | 06:49 PM
E-mail sent
calaban
May 18, 2020 06:43 PM
Hobbyguy
May 26, 2015 02:15 PM
LimitedEd1LE
May 18, 2015 01:24 PM
joe777107
Dec 1, 2014 09:32 AM
98 Blue Formula
Jul 12, 2002 10:26 PM
