Does your car's heater blow colder thru the floor than the vents ?
Old Dec 3, 2004 | 10:07 AM
NEWBIE T/A's Avatar
Question Does your car's heater blow colder thru the floor than the vents ?
Mine does, and it is weird - I'd guesstimate that there is a 10 degree differential.
Makes life tough on chilly mornings !
( I hate cold weather, anyway.)
Also, on my car, it takes the **** being about 3/4 to 7/8 of the way into the red zone for any heat to be put out - is that normal ?
My '91 Suburban will fry you out of the truck, and at 1/2 slide you can feel the warmth.
Thanks !
Britt
Old Dec 3, 2004 | 10:46 AM
xfreshjiv12x's Avatar
Re: Does your car's heater blow colder thru the floor than the vents ?
do you have a hypertech programmer or somthing that lets you adjust the fans to run cooler? It makes your heater run cooler too.
Old Dec 3, 2004 | 10:52 AM
NEWBIE T/A's Avatar
Lightbulb I do, but ...
It is set to optimize the factory 195 stat temps.
Their website does not show the specifics, but it seems like fan 1 comes on around 205 degrees as opposed to the factory's 218 or so. I would think 200 degree temps would be plenty sufficient for heat.
I have a 195 stat in the Suburban, and it blows plenty warm.
Britt
Old Dec 3, 2004 | 11:18 AM
I dont know? But I know on my 95 and my cousins 94 it blows MUCH cooler.
Old Dec 3, 2004 | 12:01 PM
Z28SORR's Avatar
I'm confussed, my heater blows hot air, my A/C blows cold! You should be getting plenty of hot air with the temp selector at full hot. I have to turn mine down after engine warms up. Normally to about the 1 o'clock position. If you are getting different temps. from the upper and lower vents you probably have a sicking HVAC door. These are internal to the HVAC housing and a pain to diagnose and get at.
Britbilly
Jan 7, 2015 08:49 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
Black93lt1
Nov 21, 2014 07:30 PM
