Tapping Rev limiter in auto?
Old Oct 5, 2002 | 02:52 PM
Fake94SS's Avatar
I have a 94 auto and heard that if i sprayed i might tap the rev limiter. My friend has a 01 auto and sprays and hasnt tapped it yet. do i need a window switch or not really, any info is appreciated
Old Oct 7, 2002 | 09:43 AM
BAD 97 WS-6's Avatar
You need more than a window switch. You should also have your rev limiter bumped way up, then get an ignition system with the soft touch limiter. You want that stock rev limiter way out of reach. This added safety will save your motor. A freind of mine busted a piston because he hit the rev limiter while spraying, and he had a window switch. The stock limiter is murder when N20 is involved.
HarleyZ28
Oct 5, 2015 06:23 AM
detroit1994z28
May 14, 2015 12:09 AM
cristian1311
Apr 22, 2015 10:20 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
