any help would be appreciated
Old Nov 6, 2004 | 01:16 AM
klpps's Avatar
Hey guys,
I've been stumped for the longest time on this. I have a Legacy 1600 watt amp model #LA870. Things worked great for about two weeks and then the amp went into protect mode. I'm a total newb and was wondering if I could get some help.
1- What are some common newbies ways of sending an amp into protect mode?
also when I unplug EVERY thing except for the power and ground, the protect light is still on. Is there a special way of getting the amp out of protect mode? Because shouldnt it not be in protect mode w/ only the power and ground?
Old Nov 6, 2004 | 08:01 AM
97FormulaWS-6's Avatar
Re: any help would be appreciated
Sounds to me like the amp may be shot... normally if it won't come out of protection mode, then something is wrong internally.
But check for shorts anywheres in your wiring, good/bad grounds, proper connections to the amp, etc...
Other than that, I'd just say talk with someone locally who has equipment and start swapping parts and see what works and what doesn't. Heck, I've got amps just sitting on the shelf in the basement, and in a couple of my cars I can very easially swap out/in different amps. Most peoples setups are this way, it's just a matter of disconnecting a few wires and you can swap stuff.
Formula Steve
Sep 19, 2023 08:31 AM
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
z28newbie
Sep 9, 2015 10:26 AM
