is it possible that my tps voltage is low, causing my trans not to downshift at WOT?
Old Oct 11, 2004 | 06:57 PM
zo6vette's Avatar
i measured my TPS voltage at WOT and it reads 4.38 volts, i was wondering if my tps voltage is to low at WOT, can this be causing my car not to downshift into second gear at WOT when crusing at speeds of 45 mph or faster? do you guys think that my TPS voltage is low? can this be causing my downshift problem at WOT that the pcm doesn't see full tps voltage at wot?
Old Oct 12, 2004 | 05:18 AM
AL SS590 M6's Avatar
Re: is it possible that my tps voltage is low, causing my trans not to downshift at WOT?
Not likely. I answered this in your 2 other posts about the same thing.
Old Oct 12, 2004 | 01:17 PM
Coolformula's Avatar
I think so I have a lt1 one with the automatic, the tps sensor was shot, and it i WOT the car it would upshift actually, repleced that, and been fine since over 20k ago.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
edman
Jan 22, 2015 02:45 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
