New aluminum pushrod V10 coming from GM
Old Oct 4, 2004 | 08:01 PM
Z28x's Avatar
from GMinsidenews.com
Escalade is planned for the V10, This seams like a logical choice for the Silverado SS too.
GM sources said the V-10s are intended for use in such vehicles as the Cadillac Escalade, an SUV, and the Escalade EXT, a sport utility truck with a cargo box at the rear. Those vehicles are available with V-8 engines only, as GM doesn't currently have a V-10 in its product line.
As power options in those vehicles, the big automaker figures the 10-cylinder units will attract more Cadillac buyers and enable the company to increase its share of the luxury truck market. As conceived, the V-10s are overhead-valve (OHV) units based on GM's existing 4.8- to 6.0-liter small-block V-8s.
The V-10 is a separate design from the Cadillac Cien V-12 concept engine introduced last year, a GM source said. That engine was based on the dual-overhead-cam Northstar V-8. The V-10 also is smaller, and considered to be more practical, than the OHV V-16 concept engine introduced early this year by GM in its experimental supercar, the Cadillac Sixteen.
The V-16 is not a viable candidate for production, GM sources said, but the DOHC V-12 is. However, the V-12, which is also all aluminum, is more likely to be used in cars than trucks and is not as close to production as the V-10, one GM source said....more
Old Oct 4, 2004 | 08:35 PM
SNEAKY NEIL's Avatar
Re: New aluminum pushrod V10 coming from GM
Wow, I didn't see this comming. This is great news. V10 power in the trucks...........I like the sound of that. I wonder what other applications this might have? I guess it could be for the STSv although the ohv might not cut it for people who value the placement of the cams more than output.
Old Oct 4, 2004 | 08:52 PM
Meccadeth's Avatar
Anyone remember the concept LS1 V10? This is going to be like that but on the LS2 level :droolsmore: I wonder if they might try fitting this into a car down the line....XLR seems to be an appropriate placement.
Old Oct 4, 2004 | 09:52 PM
HAZ-Matt's Avatar
Why a V10? Is it going to be like Dodges V10, where they just slapped two more cylinders onto their V8?
Old Oct 4, 2004 | 10:10 PM
Melee Penguin's Avatar
Escalade-V? or was that getting a V12?
Old Oct 4, 2004 | 10:26 PM
number77's Avatar
that twin turbo v-10 is looking more real everyday.
Old Oct 4, 2004 | 11:01 PM
Big Als Z's Avatar
This is gunna be GM's heavy duty engine, probably replacing the 8.1 in HD in trucks. GMT900 is being made for the V10
Looks like this is gunna be a truck-only engine, but ya never know. But what else would this be put in?
Big Caddy? With Caddy trying to move up market, why put a OHV "outdated" pushrod engine in there car...but they did it with the Sixteen...
Maybe a big Buick?! That would be awesome.
Old Oct 4, 2004 | 11:11 PM
90 Z28SS's Avatar
Im sure this engine has evolved quite a bit since, but this LS based V-10 idea was canned way back when and the 8.1 was chosen instead . Kudos to GM , as this seems to be a pretty awesome engine . Hot Rod ( errr , I think ) did a full feature quite awhile ago about the GM V10 that coulda been in the current gen trucks .
Old Oct 5, 2004 | 06:49 AM
Gold_Rush's Avatar
My thoughts exactly. Buy why dump the 8.1 v8? Unless i'm wrong, its output was better than the Ford v10, and tq was about similar. Is there some sort of advantage with going with a more cyl engine?
As for the engine itself, i'm with al. I doubt we'll see this in cars, let alone a Cadillac.
Old Oct 5, 2004 | 06:54 AM
305fan's Avatar
Ford V10 is upgraded for this year. 3 valve head, 355hp and slightly more torque then the 8.1L
Old Oct 5, 2004 | 07:06 AM
PacerX's Avatar
Why dump it? It's old and heavy.
Yep...
You use the same pistons, rods, main bearings, pushrods, rockers, springs, retainers, locks, head bolts, lifters, throttle body etc... and drive the amount of money required to manufacture all of the LSx family of engines down. Then... if you're smart... you take some of that money and roll it right back into engine development to pay for your high performance variants like the SS series.
My only real concern with the engine is this:
I'll bet anyone here lunch that a splayed valve engine like the Rat will out-flow an LSx based head hands down. My hope would be that Powertrain would return to looking at splayed valve designs for future LSx development specifically pertaining to high horsepower applications... unless of course the 3-valve engines are going to become a reality.
I guess if the 3-valve never happens, my ideal development of the LSx family would be:
Splayed valves
5 bolt heads w/ thicker decks
Coil-on-plug ignition
Cam phasing
Those changes right there basically make it a whole new motor.
Given all the advances since the Rat made it's debut roughly 40 years ago, I keep coming back to the idea that if the technology was applied to a Rat we'd have a killer.
Don't get me wrong... the LSx family is the best small block ever...
I just want to see the best Rat ever... it would mix the best of the new with massive displacement and an even better head design than the LSx.
Old Oct 5, 2004 | 07:37 AM
MrDude_1's Avatar
The aluminum versions could enter the market with 210 pounds or more apiece of finished aluminum components, company sources said. The Detroit-based automaker doesn't currently build an engine with that much aluminum.
duuuur. they make all aluminum engines... this ones just bigger. thats why it uses that much aluminum. why the hell is this even in here? if i was a english teacher, id circle this and tell them to cut it out. WTF.
Old Oct 5, 2004 | 07:45 AM
Z28x's Avatar
Looks like the V10 is for trucks, cars like the STSv and XLRv will get a DOHC Northstar V12 (unless they get a S/C V8).
Old Oct 5, 2004 | 11:03 AM
R377's Avatar
It becomes more difficult to meet emissions when the cylinders get too big. The fuel at the very edges of the pistons above the rings is a long way away from the plug and it's difficult to make it burn reliably. IIRC, that was the focus of a fair bit of development on the 8.1, and maybe it was only good enough to buy them some time.
Old Oct 5, 2004 | 11:06 AM
R377's Avatar
Originally Posted by PacerX
...my ideal development of the LSx family would be:
Why is this? When GM switched from the SBC to the LSx, they went from 5 bolts down to 4. This gave them much more freedom in the cylinder head design to optimize flow. Especially on an OHV engine, I think it would be a step backwards to go back to 5 bolts.
