Old Dodge Magnum Engine
Old Oct 3, 2004 | 01:10 AM
Melee Penguin's Avatar
Could anyone tell me exactly what makes the engine a "Magnum" there's an older guy I know that is irked with the newer "Magnums" and he says if it doesn't shake the car then it's not a Magnum. Instead of following that could someone give me technical specs on the "Magnum of old"?
Old Oct 3, 2004 | 08:16 AM
pearlpurple's Avatar
Re: Old Dodge Magnum Engine
examples might be heavier valve springs either stronger or double/triple valve springs, larger cam, intake, bigger carb, better flowing exhaust, maybe ported, stuff like that.
Old Oct 5, 2004 | 05:36 AM
And that's compared to the regular dodge v8 back then right?
Old Oct 5, 2004 | 12:27 PM
angel71rs's Avatar
The Magnums were the perf version of a particular engine. A 383 in a pedestrian sedan would have a tiny cam and 9-1 compression. The Magnum would have a bigger cam, 10-1 compression and a 4 barrel, and would end up in a performance car with a decent gear ratio and dual exaust. Magnums were mid level engines. Highest perf versions would be the Max Wedges, 6 barrels, or the Hemi. Cams in Magnums were not huge like the W-30 Olds or the L-88's, so not a lot of fender shaking going on. Very usable as a daily driver, like the 350hp version of the SS396. Until the Gas Crisis and unleaded low octane fuel came along.
Old Oct 5, 2004 | 07:48 PM
RoadRnnr69's Avatar
If you need further info check out my club website
www.440sixpack.com
There is a tech page where you can ask.
Old Oct 8, 2004 | 11:02 PM
69camroking's Avatar
Bravo, im impressed, but why are you on a camaro forum?
Old Oct 9, 2004 | 09:01 PM
RoadRnnr69's Avatar
I have a 78 Camaro in the garage also, it's a 4 speed so I couldn't pass it up.
Old Oct 13, 2004 | 12:51 PM
tom2's Avatar
Way back when I used to hear the term Magnum Heads on the old Mopars. I figured the Magnum had better heads, more compression, than the base engines. Used to mean something back then.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
alliance12364
Mar 6, 2015 04:39 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
