383 stroker help
Old Oct 3, 2004 | 01:04 AM
bazzi's Avatar
383 stroker help
hi, i downloaded some files that are in the bin format and i want to convert them to the LT1 format. how do i do this? i got a 383 stroker, stock heads that have been hoged out with a mild cam. im running a wet nitrous kit with a 175 shot. i want to look at the files to give me a guide line on how to tune my car. do u have any suggestions on how i should tune my car and where to start?
thanks,
baz
Old Oct 3, 2004 | 06:21 AM
smoknta's Avatar
Re: 383 stroker help
bin format is what the LT1s use.....you just need some software to read it
I use datamster for my 93
Old Oct 3, 2004 | 06:22 AM
smoknta's Avatar
sorry....i meant Tuner Cat
Old Oct 3, 2004 | 02:55 PM
bazzi's Avatar
so where can i download the tuner cat?
Old Oct 4, 2004 | 10:30 AM
smoknta's Avatar
www.tunercat.com
Old Oct 5, 2004 | 10:39 PM
Dan K's Avatar
According to your sig you already have LT1 edit...
If that's the case and you're trying to open a bin file I don't think that LT1 edit will open it. Someone wrote a program that converts LT1 Edit files to bin files and vice versa.
If that's all you need, do a search for it and you should find a link to it.
Old Oct 6, 2004 | 04:12 AM
bazzi's Avatar
okay thanks. my car is running alittle lean right now. i change the a couple things on the spark table and thats all but now my car is running a little lean. should i just use the pe tables to richen it up
Old Oct 6, 2004 | 08:56 PM
Dan K's Avatar
Depends on where it's rich. WOT? Idle? Part throttle?
Quickss96
Jan 29, 2016 05:56 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
