typically, what will a 300Hp car run in 1/4??
Old Oct 1, 2004 | 01:20 AM
street demon2k3's Avatar
im hoping to get a hair past the 300hp mark after i get the LT's and tune, but i cant get to the track till a few more months. im just wondering what to expect when i do get to the track? so far i have:
functional ram air
52mm TB
Lt's/ORY
cutout
3000 stall
removed sway bar
et streets/skinny's
i just dynoed 269hp/284tq, but on monday im going back to dyno w/ LT's. i am shooting for 12.9-13.3, if i cant hit the 12's im getting 4.10's, 1.6rr's, and some suspension thanks for any imput
Old Oct 1, 2004 | 02:07 AM
LS1_03's Avatar
Re: typically, what will a 300Hp car run in 1/4??
I've got LTs, custom 3" ypipe, 3" Hooker catback, no cat, Moroso CAI, 160º Thermo, and a light tune. The rear still has 2.73s and stock stall. I put down 277rwhp/314rwtq. I've managed a best of 13.58@102. Best trap of 104. With your stall and sticky tires+skinnys, you should be hitting low low 13s in good weather. I guess you can count the 52mm TB. You should hit what you're wanting. Good luck with it.
Old Oct 1, 2004 | 10:04 AM
andy katzelis's Avatar
Pro stock et formula says, 3650 lbs, 300rwhp, 13.38 at 101.8. All perfectly matched to run that number, gear, converter, tires, cam, etc....
Old Oct 1, 2004 | 10:28 AM
CANTONRACER's Avatar
A good bud of mine that I would bet makes 290 rwhp/320 rwtq ran in a full weight 94 automatic f-bod a 13.03@105.11 the other night.
Old Oct 1, 2004 | 04:48 PM
stereomandan's Avatar
I doubt that you'll hit 300 rwhp, but if you do, then you could probably see mid 13's to low 13's. I just don't want to get your hopes up too high. Hitting 300 rwhp with an A4, 3000 stall, and your other new mods is still very optimistic.
Dan
Old Oct 1, 2004 | 04:57 PM
SS Mark's Avatar
You dont need 300 rwhp to run 12's. Just the right setup mainly and traction, your stall with 3.73's and a good 60' should get you 12's.
Times in sig are with 268 rwhp, obviously power helps too but a good stall/gear combo is just as important.
-Mark
Old Oct 1, 2004 | 06:17 PM
mod313's Avatar
Very true SSmark, the biggest problem with most cars is too little chassis/suspension. Far too many simply thro more hp at their cars instead of working on the car itself and unlocking what they already have.
Weather and track prep make a massive difference.
Old Oct 2, 2004 | 12:17 AM
Jeffs94Z28's Avatar
SS Mark what exactly do you have in your car?
Old Oct 2, 2004 | 01:38 AM
SS Mark's Avatar
3.73's. alum ds., flp trans w/ vig2800 stall, y-pipe, 3" cat, 3" catback w/cutout, UD pulley, cai, homemade ramair, and some various suspension mods, on BFG DR's, oh and full weight
New times coming very soon
-Mark
Old Oct 3, 2004 | 08:37 AM
since i am going into the suspension soon what would you guys suggest getting first? i was thinking LCA's w/ relocation brackets, then torque arm, after that SFC's. what do you guys think? i really want to hit 12's with just bolt ons.
Old Oct 5, 2004 | 05:14 PM
big dave's Avatar
With 271 rwhp I ran 13.04 @ 103 with a slipping tranny. My raceweight was around 3700 lbs. Hope this helps.
Old Oct 5, 2004 | 06:05 PM
Tekprodave's Avatar
Scratch all the above items because they won't help much at all for drag racing. If you want to do suspension get drag launch springs and adjustable shocks. 12's are not hard to acheive in a full weight bolt on car even with stock suspension. But weight reduction is a beautiful thing. If you are willing to sacrifice a ton of comforts you can hit 11's without touching the motor. It's very cost effective and running light sure feels good.
Old Oct 5, 2004 | 06:37 PM
DarkHorse's Avatar
I was thinking i'd make around 290 as well. Ended with 313/356 and had 3/4 tank of gas, full weight when I went 13.03 @ 105.11 last Wed. The car has went 12.998 on a better track - currently waiting for a tune to hopefully get the a/f dialed in right.
Old Oct 5, 2004 | 09:45 PM
WickEdSix98's Avatar
I dynoed 261/246 at the wheels on my v6, and at altitude I ran a 13.70@99.84mph. The air was 4400'DA, 27.23 baro, 66.7*, and 70% humidity, a 300 horse car should easily run 12's closer to sea level
