List of fastest LT1's (thru November 2021)
Old 10-01-2004, 12:04 AM
meengreen 94z's Avatar
QUICKEST LT1 LIST
Power Adder List (9.99 and under)
Jonathan Atkins / Tick Performance - Current fastest/quickest LT1 - Turbo LT1 / T56 - November 2021
6.977 @ 211.10 MPH
Facebook Post
Tony Shepherd - 11/22/2020
7.38 @ 187.00
93 Z28, 396 LT1, solid roller, single-plane, AFR 235 , single turbo, 3150 lbs, PG
Tyree Smith / Ty Tech Performance -
8.039 @ 173.63
3rd Gen, 383 AFR 210's, FAST EFI, Opti, rear mount 88mm turbo, street driven, A/C, PS, full audio system, full interior/carpet,
https://www.camaroz28.com/forums/dra...-smith-884825/
"Big Rick" - Rick Intrau
1996 Formula WS6, 396ci LT1, AFR 215rr heads, 91.5mm Turbo, Madman suspension
1/4: 8.08 at 172
"slammed98gmc" (Tony)
Non F-Body (S10) - 383, single-plane, solid roller, 98mm turbo, LE TFS 23*, FAST EFI, PG
1/4: 8.394@166.19
1/8: 5.444@133.46
"Cherry Bomb"
Non F-Body (Impala) - 410ci, AFR heads, 2-stage N2O
1/4: 8.501@158.06
1/8: 5.424@128.70
Lisa33(Non 4th Gen)
383LT1, maxed out procharger F1, ported TFS heads, Bret Bauer cam, half filled block, JW PG, 8 3/4 3.91 rear end, 12.5x30-15 slicks
60 ft.:1.25
1/4: 8.54@151.6
1/8:5.42@128.6
Taner Bosnali
1996 Camaro SS - 399ci, Liberty T56, N2O, 3,500#
1/4: 8.81@155.05
Chris Sikora - took the Fastest LT1 title on October 18, 2003
383ci LT1, AFR 220cc heads, Vortech YSi trim
1/4: 8.928 @152.61
1/8 5.750 @123.96
60 foot: 1.341
Jakesz28
8.957 @ 151.60, 1.349 60ft, 5.74 @ 122 1/8, 94 Z28, 383 LT1, Nitrous, power glide, fabbed 9" (first 8 sec nitrous LT1)
Taner Bosnali
1996 Camaro SS- Fastest 4th gen LT1 6-speed
399ci LT1, AFR 227cc heads, Nitrous, T-56
1/4: 8.97 @ 155.23 mph... 1/8 5.80 @ 123.28 - 3600 #'s
60 foot: 1.349
George Baxter-held fastest LT1 record, November 2001
1997 Camaro SS Convertible, 383ci LT1 with YS-trim(?)
1/4: 9.04 at 155.33
Jeff Gilbert
96 TransAm raceweight 3556# 398 D1 procharger 100 shot
60ft1.36
1/4: 9.06@151.48
1/8: 5.82@121.1
Brian Edwards 1989 Camaro RS (NON 4th gen., stock suspended)
360ci LT1 w/ nitrous
1/4: 9.06 at 148
60 ft.: 1.27
Vince McCauley "Spray the way"
383 LT1 AFR 227cc heads, solid roller w/ 350 shot
1/4: 9.08 at 159.79
Dave Diluca
1994 Camaro Z28-took the title as fastest LT1 on July 2, 1999
396ci LT1, w/ nitrous, powerglide
1/4: 9.11 at 154.59
1/8: 5.87 at 120.88
60 ft.: 1.36
Dave Ducote/Madman- held the fastest LT1 record,
1994 Formula, 381ci LT1, ATI Procharger 20psi, TH400
1/4: 9.18 at 152 (October 2001)
Ric Fleck "Tubby"
1997 T/A
F1 procharger w/ small nitrous shot
1/4: 9.20@ 145.9
60 foot: 1.27
Brady Mcnew
1996 Camaro Z28
1/8:5.91 at 112
60 ft.: 1.49
Jay Billingsley,
1993 Z28
9.29? at ??? (more info needed)
Jason Warren
1995 Camaro Z28
350ci LT1, Trickflow heads, w/ 300 shot of nitrous
1/4: 9.33 @ 142
1/8:5.87 @ 117
60ft.:1.28
Voss Boreta.- QUICKEST IMPALA SS
96 Impala SS
383 LT1, F1R Procharger, TH400, 3000 Stall, 3.50 Rear, 4150# raceweight
1/4: 9.394 @ 149.03.
60 ft: 1.56
Rob Cowling "Yellow Z28"
Camaro Z28
383 LT1, AFR 227cc heads, 85mm turbo, TH400,
1/4: 9.34@149
1/8: 6.079 @ 120.55
JM385LT1
1996 T/A
1/4: 9.404 @ 141.79
1/8: 6.001 @ 116.06
60 ft: 1.37
Stefan D.
1993 Trans Am
396ci LT1, LT4 heads, stock pcm, nitrous
1/4:9.41 at 141.12
Lisa33
1995 Camaro Z28
F1-SC ported TFS heads 17psi FMIC 4l80e 3000 vig
1/4: 9.44 @ 143
1/8: 6.02 @115
1.69 60ft
Jeff Stevens
1996 Camaro Z28, 383ci LT1, Vortech YS trim
1/4: 9.47 @ 148mph
1/8: 6.34 at 112.05
Camaro Z28
383 LT1, AFR 227cc heads, YS trim (now YSi trim), TH400, 712rwhp at 19.5psi
1/4: 9.52 at 142
1/8: 5.98 at 116 (around a 9.20 at 147-149 in the ¼)
60 ft.: 1.30
Ralph Olivarez/Madman
1994 Camaro Z28
355 LT1, LT4 heads, TH400 w/brake, ProCharger D-1, FAST system, Madman suspension
1/4: 9.56 @ 141mph
"JeffB94z"/Induction Motorports
1994 Camaro Z28
396ci LT1, Vortech T-Trim, 50 shot, TH400, F.A.S.T. EFI
1/4: 9.57 @ 142.7
60 ft: 1.35
Darren Nichols "Chevyguy3”
1995 Pontiac Formula 396, cam 254/259, .664/.656, 112LSA , "Stage 3" LT4 heads 2.00/1.60 valves, 279cfm , TH400, w/ 200hp shot nitrous
1/4: 9.63 at 142
Jim Moran "INTMD8"
1997 Camaro SS- 6-speed
357ci LT1, 9.2-1 comp. AFR 195cc heads, 218/218 cam, Twin GT61's, T56, 847rwhp 847rwtq,, raceweight at 3,740lbs.
1/4: 9.68 @146.40 mph
"BigkevC5"(car now owned by East Coast Supercharging)
1997 Camaro Z28-Stock Bottom End record holder
350ci LT1 w/ LT1 ported heads, Cam, boltons, 150 shot
1/4: 9.75 at 139
Daren Wlodarczyk
1996 Trans Am WS6 Convertible
398ci LT1, AFR 227cc heads, 300shot of nitrous, 811rwhp and 928rwtq
1/4: 9.763@138.49
60ft: 1.372
Ellis "OneFlyn95z28"
1995 Z28 - N2O
1/4: 9.827 @ 137.37
1/8: 6.266 @ 110.51
60-ft: 1.414
T/A LT1
1995 T/A RamAir, 355" LT1, Jet Hots, PI 3800 conv, 3.55, CC306, Lloyd Elliott Trickflows, 3,500lbs
1/4: 9.83@136mph
1.50 60'
hvyss
96 ImpalaSS - 4,200#, 385, AI H/C/I, TH400 w/brake, 175-shot
1/8: 6.31 @ 109
1/4: 9.92 @ 134.89
60-ft: 1.49
Jordon Musser- 6-speed
1994 Camaro Z28
401ci LT1, AFR 210cc heads, T-56, Solid roller cam, 225shot
1/8: 6.43 at 112
Naturally Aspirated (10.99 and under)
Joe Overton
1994 Trans Am-First N/A LT1 in the 9's- Holder of the fastest Naturally Aspirated stock susp. LT1 4th gen-Holder of the fastest 60 ft. on stock type suspension(1.249 )
388ci LT1, AFR 227cc heads, Solid roller cam, TH400 w/ transbrake
1/4: 9.34@142.66
1/8: 5.93 at 115
60 ft.: 1.245
Rick Abare
383 LT1/Ai TFS 215 cc race port heads/Pro Ram intake/ FAST computer/Ed Wright tune
1/4" 9.50 @ 139 mph
60-ft: 1.24 (rear wheels)
Sammy Vedros
1st Gen Camaro(non stock suspension)
396 LT1 NA
1/4: 9.62 at 13X
60 ft:1.29
Steve Quinn
1995 Camaro Z28, 370ci LT1, Ported factory LT1 casting heads, w/ race wt @ 3052
1/4: 9.713@138.16
1/8: 6.277 at 108.3
60ft: 1.271
Mindgame-Fastest Naturally Aspirated 6-speed LT1
383 LT1, 15* heads, LT4 intake, T56, 570rwhp
1/4: 9.82 at 138.6mph
1/8:6.39 at 108.7
Vince McCauley
383 LT1 (carbed), AFR 227cc heads, solid roller
1/4: 9.93@135
Taner Bosnali-6speed
1996 Camaro SS -399ci LT1, AFR 227cc heads, T-56
10.09 @ 135.71 mph, 1.42 60' -
Dave Odehnal
1993 Camaro Z28 - Ported factory LT1 casting heads and intake.
1/4:10.15 at 134mph
60 ft: 1.37
"joelster"
1994 Z28 - 414ci, AFR 227, solid roller, pump gas, 3,045#, TH350
1/4: 10.154@133.65
1/8: 6.476@106.78
Benjamin Moore III "ou812/z28"
1994 Camaro Z28 - 396 LT1, AFR 210cc heads, th350, stock pcm, 467rwhp and 517rwtq, 3325 raceweight
1/4: 10.18 at 132
60 ft: 1.38
N2ODAVE
396 LT1 SB2.2 heads, SR, G-Force 5 speed
10.33 @ 132.97
1.58 60'
Tim "95Bird"=6speed
1995 Pontiac Formula - T-56, 355ci LT1, ported lt4 heads, solid roller cam, Moser 9", 4.71
1/4: 10.39@131.6
60ft: 1.42
Randy Etheridge "rje"
94 Z28 - 383 LT1, AI 200cc, pg, jesel shaft mounts, 3300lbs
6.55 @ 101mph
Darren Nichols "Chevyguy"
1995 Pontiac Formula - 396, solid roller cam, LT4 heads, TH400
1/4: 10.46 @ 128
Chrism400
1995 Z28 - A4, 396 solid street roller, Lingenfelter CNC heads
1/4 10.52 @ 128
1/8th 6.67 @ 102
Clyde Moore
383 LT1, stock head castings, TH350, stock suspension, EFI non carb intake
1/4: 10.66@128
Dave Jones
Solid Roller 383, AFR 210, 264/271 .688/.660,
10.73@127(1.55 60ft)
1/8 6.86@101
Dave Smith
1995 Trans Am - M6, 396, solid roller, AFR heads
10.76@131mph
Jordon Musser
1994 Camaro Z28 - 401ci, AFR 210cc, T-56, Solid roller cam, 471rwhp/ 455rwtq
1/4:10.80 at 130
1/8: 6.9 at 100
Stefan D
1993 Trans Am - 396ci LT1, LT4 heads, stock pcm
1/4:10.82 @ 128
T/A lt1 Clint
1995 T/A - LE3 stock castings, LT1 intake, LE S/R, 383, pumpgas, 4k vigilante/TH350, 12bolt 4.10's, Madman/BMR suspension, 3,450lbs, stock PCM.
1.47 60'
1/4: 10.82 @ 127.8
1/8: 6.90 @ 99mph
Travis Linville
1994 Z28 Hardtop - 396, GTP Stage 3, ported intake, Hooker LT, solid roller, M6, Street Twin, Moser 12 bolt, 4.11
1/4: 10.83 @ 127
Ken "Kamba93LT1"
1993 Z28 - 355,TEA heads, hyd. cam, TH400, KTRE 12-bolt, 4.56, 28x9.0 slick
1/4: 10.983 @ 120.93
1/8: 6.950 @ 98.23
60 foot: 1.442
QuikSS
1995 Impala SS(clone) 383 LT1, TFS heads
10.965 @ 123.71 1/4 mile
6.994 @ 99.13 1/8th
1.537 60'
Warren Dempsey (The Engineer)
1997 Z28 - A4, Golen 396, AFR-195 by Lloyd Elliott, Comp custom-grind S/R cam, Kooks headers, 12-Bolt w/ spool and 4.30s, 3440# race weight.
1/4: 10.977 @ 126.9
1/8: 6.98 @ 97.47
60-ft: 1.49
meengreen 94z is offline
Old 10-01-2004, 07:03 AM
taner's Avatar
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Re: List of fastest LT1's
Sorry Taner..... we exceeded the character limit in the post above, and need to move the bottom categories to your post
FASTEST 6-SPEED LT1
Jonathan Atkins / Tick Performance - Current fastest/quickest LT1 - Turbo LT1 / T56 - 11/01/19
7.309 @ 199.10 MPH
60-ft: 1.198
Link to video on LTXTech Facebook page
FASTEST BOLTON LT1
Tom Cowle
1995 Camaro
Edelbrock Suspension, MT Drag Radials, CSR ewp, Hooker lt's, "junk parts", Mike Blood transmission
1/4:11.702 at 114.30 mph
60 ft:1.55
FASTEST INTERNALLY STOCK LT1
Craig Miller/ Madman Racing
1996 Trans Am
hooker longtubes, mufflex exhaust, Moroso cold air, and a 52mm t/b. th400 with brake, 9" rear end. 150 dry NOS kit. Madman Suspension. Stock interior and all accessories.
1/4: 10.86 @120
60 ft: 1.38
FASTEST CAM ONLY LT1
Frank95z
1995 Z28, stockheads ,A4,52TB, cold air,hooker longtube headers, Joe O custom grind cam, 1.6rr,Strange 12bolt,QT Pros, Vig3200, 3325lbs
1/4: 11.163 @ 119.86
1/8: 7.05 @ 96.00
1.49 60 ft
FASTEST HEADS/CAM LT1
James Eddy
stock ported heads and intake ,hyd.
1/4: 10.88 @ 122.81
1/8 6.90 @ 99.08
FASTEST HEADS/CAM LT1 - B-BODY
Pat Gish "IowaSS"
96 Impala SS, AI LT1 heads/cam
1/4: 10.98@122.0
1/8: 6.96@97.6
FASTEST STOCK BOTTOM END LT1
1997 Camaro Z28
1/4: 9.75 at 139
FASTEST STOCK BOTTOM END LT1 - B-BODY
Pat Gish "IowaSS"
96 Impala SS, AI LT1 heads/cam, 100-shot
1/4: 10.35@128.2
1/8: 6.53@103.5
actually Steve Quinn went 9.70 @ 137ish at the N vs S event earlier this year!
Last edited by Injuneer; 09-10-2020 at 10:52 AM. Reason: Moved from 1st post due to character limit.
taner is offline
Old 10-01-2004, 09:08 AM
andy katzelis's Avatar
Chevyguy3's name is Darren something. Hey may not want to be known. He's a local hero round here. He wuped up on my xss last time out, awsome car. He sold the car now. He'll probably chime in eventually.
andy katzelis is offline
Old 10-01-2004, 09:45 AM
Thanks, I thought I remembered someone saying that, but couldnt find any proof otherwise.
Old 10-01-2004, 09:49 AM
Thanks, I guess I'll wait until he says something then
Old 10-01-2004, 02:58 PM
timelord's Avatar
George Baxter!!
8.6 @ 160+ MPH
timelord is offline
Old 10-01-2004, 04:22 PM
MBonZ28's Avatar
Originally Posted by timelord
George Baxter!!
8.6 @ 160+ MPH
baxter is no longer sporting an LT1
I am not sure if Brady 9.55 was with and Lt1 either
Daren WikidTA should be up there too. I think he went 9.7s with his 97 T/A a few years back
MBonZ28 is offline
Old 10-01-2004, 04:23 PM
George Baxter!!
8.6 @ 160+ MPH
Unfortunately he doesnt have an LT1 in it anymore. His fastest run with an LT1 was a 9.04
Old 10-01-2004, 04:28 PM
Brady ran the 9.55 on an old setup. His new setup/car was supposed to be even faster, but I havent heard much about it in a while.
Do you have anymore information about Daren "Wikid TA"? Id include him if I had an exact time and mph and more information on his car. Thanks
Old 10-01-2004, 04:30 PM
timelord's Avatar
OOOOOPPPPSS !!! Sorry about that,I didn't know!!!!!
timelord is offline
MBonZ28's Avatar
brady has had a few setups. think that 9.55 was with the big block
MBonZ28 is offline
Old 10-01-2004, 04:36 PM
MBonZ28's Avatar
http://www.wideopenwest.com/~daren96ta/
MBonZ28 is offline
Old 10-01-2004, 04:41 PM
Doh..totally forgot about Daren's convertible. Thanks
I'll look into Brady's record, you may be correct.
Old 10-01-2004, 06:02 PM
yellow Z28's Avatar
pete adams is a gen 1 sbc...still a verry nice car
yellow Z28 is offline
Old 10-02-2004, 12:29 AM
Thanks
Quick Reply: List of fastest LT1's (thru November 2021)
