What else is needed??
Old Sep 28, 2004 | 11:42 PM
mattybz28's Avatar
Well i never have planned on putting the bottle on my car, but I got a very good deal on a NX kit, and had to jump on it.... So now i'm wondering what else am I going to need??
Kit is unused, and has a purge..
I know i need a bottle warmer, nitrous pressure guage... what else though??
Colder Plugs?? any sugestions? gonna be under 150 shot..
Differnt intake elbow?? what does everyone else use?
Tune?? Spraying this on a 96 z28 with stock computer tune.. It's an Auto..
Anything else??
All the help is greatly apprietiated.. Thanks much!
Old Sep 30, 2004 | 08:14 AM
jeremyferguson's Avatar
Re: What else is needed??
Anything else??
I use tr6 plugs, I've been using them since I put the kit on and started at a 50 shot....all the way up to 150. Great for the nitrous and doesn't affect n/a as far as I can tell. I also like having an electric fuel pressure gauge that I can see when I'm spraying(you don't want to go lean). I noticed it stayed right where it was supposed to up to 100 shot....then when I sprayed 150 the fuel pressure dipped a little bit(just acouple pounds), but I decided to get a new fuel pump anyways(255lph). I also have air/fuel ratio gauges to keep an eye on things.
I also have a stock tune, which will be changing shortly via madwolfe because of the gear change(also its been running pig rich since the headers), but you don't need to tune for a wet kit because it supplies the extra fuel. Also, I've heard that nx jets their kits to run on the rich side anyways. I've also got the a4 like you. I have not sprayed through the shifts. I just let off the button right before them. A lot of people do, but if it decides not to shift and your still spraying and you hit the rev limiter, you'll be in trouble.
Old Sep 30, 2004 | 12:20 PM
mattybz28's Avatar
What about the intake elbow?? Did you just tap into the stock one or what?
Old Sep 30, 2004 | 01:02 PM
That's what I did, and most others with a nozzle kit.....
Old Sep 30, 2004 | 01:08 PM
mattybz28's Avatar
Alright, thanks a lot.... Do most auto parts places have the plugs or would i need to order them online?
Old Oct 1, 2004 | 06:12 AM
I bought mine at ramchargers(performance auto parts store), but I don't know if places like autozone or murrays have them....I think I paid like a $1.75 each. Not bad at all. I think I gapped them a little smaller than stock gap, like maybe .005 smaller.....
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
