Wheel hop after poly trans mount
Old Sep 26, 2004 | 05:58 PM
brain's Avatar
I just realized I am getting a LOT of wheel hop. I never noticed it or had any with a stock transmission mount, but I broke it at the track a couple weeks ago. I replaced it with an ES poly mount. Now the car wheelhops BAD in first. Could this be a pinion angle issue? I was thinking that maybe the mount is shorter or taller than the stock mount and now the pinion angle is off a degree or two, causing the wheelhop. All suspension is stock, except a poly torque arm mount.
Old Sep 26, 2004 | 08:50 PM
Stephen 87 IROC's Avatar
Re: Wheel hop after poly trans mount
Poly mount is usually higher than a factory rubber one. Driveline angle should be slightly different now.
Mar 13, 2016 03:39 PM
Jason Short
Jan 19, 2015 06:34 PM
x7x7
Aug 15, 2002 06:49 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
