Anyone know how to adjust a TH350 linkage?
Old Sep 26, 2004 | 10:18 AM
IRONFIST's Avatar
I installed a new shifter linkage cable on my Car. (the cable the goes from the shifter on the console to the trans').
However... now... I'm one gear back and missing first gear.
So, park is actually reverse on the trans... etc.
I couldn't find any threaded ajustment on the cable itself??
Anyone know how to adjust it.
The trans is TH350.. i'm assuming the setup should be the same as a Camaro.
Old Sep 26, 2004 | 11:19 AM
spinout's Avatar
Re: Anyone know how to adjust a TH350 linkage?
the adjustment should be at the trany with an adjustable plate bolted with 2 pan bolts
Old Oct 3, 2004 | 04:40 PM
calereeves's Avatar
Yeah, check out the actual mounting bracket on the trans pan, its got slots on it for adjustment, BUT, if that doesn't work or give you enough adjustment, I had to pull my console one time and on the actual shifter mechanism, look at the arced slot. On the front and back of that slot on the side there should be some sort of adjustable plate or stop or something(its been too long since I've seen it...). Play with taht for a bit, and between the two, you'll get it.
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
SEOJustin
Sep 24, 2015 04:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
