help me out with upping the line pressure...
Old Sep 22, 2004 | 11:47 PM
Seal's Avatar
I need to up the line pressure for my a4 97LT1... i'm using LT_Edit... what do i do?
i assume this is what i do...
Line Pressure vs. TPS vs. 0-64MPH and Line Pressure vs. TPS vs. over 65 MPH
the values for 100% and 90% is set at 90... what do i put there to get maximum line pressure....
my friend told me there is a place that'll tell me what to do to get the hardest shifts... anyone know?
Old Sep 23, 2004 | 12:47 AM
TriPinTaZ's Avatar
Re: help me out with upping the line pressure...
the easiest way is to just increase the shift pressure tables.
Old Sep 23, 2004 | 01:15 AM
Seal's Avatar
yeah, just did it... put it upto 115 after 90%
should be good for now
Old Sep 23, 2004 | 08:25 AM
1fastlt1's Avatar
There is a place near the bottom of the constant table that set maximum line pressure. It is set to 90psi. I'm not sure that you'll see anything above the 90 unless you change that. I haven't messed with it so I don't know for sure maybe someone else can chime in here.
Old Sep 26, 2004 | 09:00 AM
Dan K's Avatar
be careful...
KYWes
Jun 14, 2022 06:52 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
colts0455
Jul 8, 2015 12:21 AM
blac94Z
May 4, 2015 12:11 PM
