Weiand X-CELerator Aluminum Intke Manifold Single Plane
Old Sep 22, 2004 | 08:26 PM
85_305's Avatar
Will this intake work on my car with an Edelbrock 600? If not.. what are my other choices by Weiand, or any other well-known manufacturer?
Thanx all,
Matt
Old Sep 22, 2004 | 09:14 PM
Dave89IROC's Avatar
Re: Weiand X-CELerator Aluminum Intke Manifold Single Plane
for best use on a street driven car, it would be best to get a dual plane intake, if emmissions is not an issue, the edelbrock performer non egr or the performer RPM would be good, as for Weiand, the Stealth is a very good intake, have had personmal experiance, it is a nice intake
Old Sep 22, 2004 | 10:34 PM
Stephen 87 IROC's Avatar
That manifold is a low profile style. It's good to use to keep the carb low enough to close the hood. I used one on my old 383 but I also used a 850 Speed Demon carb and a huge solid camshaft.
I don't think it has a dual bolt pattern for the carb. Mine was for square bore carbs. If the Edelbrock is a spreadbore, it may not fit unless the intake has the proper holes to mount the carb studs and the opening is big enough for the spreadbore.
Old Sep 23, 2004 | 04:46 PM
85_305's Avatar
I have the Edelbrock p/n 1406.. I dunno what kind of "bore" it is. I have some kind of Edelbrock square bore adapter plate.. would that work with it?
Old Sep 23, 2004 | 09:45 PM
Dave89IROC's Avatar
1406 is square bore, dual pattern
Old Sep 24, 2004 | 02:27 PM
85_305's Avatar
So that would work with the manifold I had listed? But I don't want that manifold because it is a single runner.. right?
HarleyZ28
Oct 5, 2015 06:23 AM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Elcojoe
Nov 17, 2014 10:27 PM
