Drag Racers inside
Old Sep 20, 2004 | 11:37 AM
YZF/LS1 Freak's Avatar
Drag Racers inside
This is kind or a rant but when you guys race how serious are you? Me the radio is off or I block it out and the only thing I think about is wining and not getting killed, I am looking down the track or the deserted street and when I am running I am 100% aware of my suroundings and what I and the other car are doing. But I see SOOO many people (mostly females) that when they race the are screaming and talking to each other and stupid crap like that. Is it just me or is that the crap that gets people killed?
Old Sep 20, 2004 | 11:42 AM
izzyz28's Avatar
Re: Drag Racers inside
Concentration all the way. Whether at the track or on the street, I'll turn my radio off and just focus on what my car is doing and my surroundings. I can't imagine racing AND trying to concentrate on something else at the same time.
Old Sep 20, 2004 | 11:47 AM
5SPDCHK's Avatar
I do not race on the street. My car is not street legal. There is no radio in my car. It is not legal to have a passenger in my car when racing. I focus on what I am doing. I watch for where my opponent is to determine if I need to lift or not.
Old Sep 20, 2004 | 11:51 AM
Omega9's Avatar
You mean you don't scream and giggle, and try to fix your hair?
Old Sep 20, 2004 | 11:54 AM
5SPDCHK's Avatar
Well, in all honesty, if my win light comes on I may let out a bit of a squeek and giggle while slowing down. After hitting the return road and taking my helmet off, I do tend to try a little "fixing" of the helmet head. So, maybe I do scream and giggle and fix my hair when racing...
Old Sep 20, 2004 | 12:23 PM
Firehawk95's Avatar
When I used to race my car at the dragstrip, I was extremely focused. AC was off, radio was off, hair was up and out of my way, rings were off my fingers so I could grab the shifter better, and I wore the same shoes I drove the car in nearly every day so I could feel the pedals more precisely. No talking, no cellphones, no passengers.
I paid attention to nothing but the sounds of my engine, my opponent, the lights and the track. I never even knew my ET until they handed me the slip at the track shack.
So no, there was no giggling or hair-tossing until the race was over and I exited the vehicle.
Old Sep 20, 2004 | 12:30 PM
IRONFIST's Avatar
I do notice some guys keep their radio on... I like to listen to the engine so I can hear it rev up and keep an "eye" on it.
Old Sep 20, 2004 | 12:41 PM
red's Avatar
red
When racing there should be only one thing on your mind at a time. Hit the light, keep it in the groove, hit your shift points.
Old Sep 20, 2004 | 12:44 PM
TedH's Avatar
About six cars from the line I close my eyes for 30 seconds. I then press my eyes with my hands to make certain they are clear and not itchy. I check my belts, steering wheel position,seat position, any controls that are in use or not in use to verify their position.
When I turn the car on I make sure to have a minimum of two minutes running time before I burn out so the computer is fully consistent.
I note my competitor, whether ornot he is dialing slower or quicker than me. I note his dial in case I am aware of what the car normally runs and do a quick "weather" calculation to determine the odds of a sandbag. I also look across from a parallel vantage point to determine my position in relation to the strip so I know where I usually want to be.
Brief turn of the tires in the water box to wet the slicks. Pull ahead and stop. When directed I set the line loc and burn out, as the tires start to grab I roll ahead toward the line while gradually reducing the throttle until they hook. This provides a feel for the launch so I can adjust my rpms if necessary to reduce the chance of spin.
I then pre-stage. I always courtesy stage. Ithen set the rpms, and inch into the stage beam so I am at the same launch point each time.
At the launch I try and feel the amount of hook with my butt-o-meter. The 1-2 shift comes fast and I focus on hitting 6200 rpms exactly. I then immediately crank the radio to the track station in case the announcer screws up and mentions someting about reaction times. I glance at the win lights in case of my opponent red lighting. I then go back and focus n the third gear shift at 6500. Immediately before shifting I try and determine my opponents position to time my shift either early, right on, or a little late depending on whether or not I think one of us is too fast or too slow.
Immediately after the third gear shift I look for my opponent to determine my finish line strategy. Do I want to take the strip? Can I take the stripe? Are we too quick? Am I too slow? I make no decisions until after the 1000 foot mark about finish line strategy.
Yea, I'm focused.
Old Sep 20, 2004 | 12:46 PM
TedH's Avatar
I may move this to the drag racing forum later but it seems to be getting a good response for now...
Old Sep 20, 2004 | 12:48 PM
Firehawk95's Avatar
Butt-o-meter...
Old Sep 20, 2004 | 01:06 PM
5SPDCHK's Avatar
Originally Posted by tnthub
... I then immediately crank the radio to the track station in case the announcer screws up and mentions someting about reaction times...
Rick does this too when whatever he is racing has a radio.
Old Sep 20, 2004 | 01:23 PM
allmotorta's Avatar
I only race test and tune so I fully concentrate on my run and don't even worry about reaction time or who I am racing. Hell, alot of the time I don't even remember or know who I just raced. I always get horrible reaction times because if I'm going to make a pass, it has to be perfect. I will sit there until I find my desired launch rpm and then I'll take off. The radio is off, along with everything else. Most of the time I'm looking at the tach, with quick glances up to make sure I'm staying in the groove. My reaction time is normally in the .900-1.500 range
Old Sep 20, 2004 | 02:18 PM
TedH's Avatar
Not to be an ***, but how can you make a "perfect" run with a .9x reaction time?
Old Sep 20, 2004 | 03:28 PM
Kraest's Avatar
Retired
I think he was making fun of himself.
Besides, most people don't bracket race and don't give a flying crap about RTs.
Mike
