Anybody have the MAF after a front-mount?
Old Sep 18, 2004 | 03:53 PM
Chrisbequick's Avatar
Question Anybody have the MAF after a front-mount?
The turbo build has been done for a while and I'm just driving my car easy to break the motor in before I do the fuel system and tuning. My car has a bucking/surging problem after it warms up that is obviously related to a sensor. The car is okay at moderate throttle, but at light load steady-state cruising it bucks and surges and has a hard time holding a steady load. After a little research I've learned that the MAF may not like a lot of tubing in front of it for some reason. I've got mine mounted after the front-mount and about 2.5 feet from the throttle body.
The tune and injectors are stock for now, so I'm fairly certain it isn't a tune or fueling problem, and the ignition seems fine. Any ideas? Who has dealt with this problem or a similar one? Does anybody else have the MAF behind a lot of piping?
-Chris
Old Sep 18, 2004 | 04:34 PM
Sean94Z's Avatar
Re: Anybody have the MAF after a front-mount?
It's probably too close to the intercooler. The air coming out of the intercooler is probably swirling and moving all over the place, this will make the MAF not get an accurate reading. Move it to the stock location (right before the bend before the TB) and see if it continues..
--Sean
Old Sep 19, 2004 | 02:37 AM
slimdawson's Avatar
I have several feet before the maf but after the intercooler. Maf is in about the same location as stock. I have no problems like you describe.
Old Sep 20, 2004 | 10:57 AM
The comment about the turbulent air got me thinking. I have a descreened MAF, and maybe a screen would help. So I threw a stock MAF back on the car and it almost seemed like it ran worse, although I can't be sure. Oddly, though, later I disconnected the battery to reset the PCM and the car was great for about 10 miles before it slowly started freaking out again. Maybe the PCM doesn't like the turbo for some reason?
-Chris
Old Sep 20, 2004 | 02:04 PM
94 NO TOP Z's Avatar
I have a stock de-screen MAF in the stock location (after the front mount intercooler) with no problems.
Old Sep 20, 2004 | 03:31 PM
Sean94Z's Avatar
-Chris
How about if you unplug the MAF all together? How does it run?
--Sean
Old Sep 22, 2004 | 03:48 PM
CJ's Avatar
CJ
My MAF is mounted about 2.5-3 feet before the TB after a front mount. Has always been like that and ive never had a problem with it.
Sounds like O2s or a couple of crossed plug wires to me.
Old Sep 24, 2004 | 10:47 AM
Sean, I'll try your suggestion tomorrow.
CJ, your suggestion got me thinking. I put the O2s in the downpipe, about two feet away form the turbo. I figured that the distance wouldn't be an issue since they're heated. Maybe the O2s need to be closer to the exhaust port?
-Chris
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
