Spraying out of the hole question...
Old Sep 14, 2004 | 09:22 PM
94-3.4's Avatar
Would it be advisable to spray an A4 with a 100 shot out of the hole WITH OUT a window switch? I am just a little concerned since i launch from an idle.
Old Sep 14, 2004 | 09:34 PM
94Z28rag's Avatar
Re: Spraying out of the hole question...
My friend has the ZEX wet kit on his LT1 automatic Formula and he sprays a 125 shot off the line, its on a WOT switch and he just mashes it with DRs and goes. He hasnt had a problem yet, and he has no safety stuff.
Old Sep 14, 2004 | 10:36 PM
Fuels94TA's Avatar
I've have all the time, even took it up to 150 shot. But it wont work to well unless you have traction to back it up.
Old Sep 16, 2004 | 05:51 PM
Sunsceamer's Avatar
What RPM will your 3.4 hold at the line before you let go of the brake?
Old Sep 16, 2004 | 10:44 PM
kirschman's Avatar
I was running a 150 shot wot switch, window switch (on-3k off-6k). I dump the clutch at bout 5 to 55k WITHOUT going to WOT, then, bout 10ft. out if its hooking, i nail it. Works good for me so far. A couple of times i got some bad wheel hop bout at the 60ft. mark but the BMR lca's fixed that. I had a few mid 1.7's. Not bad for a stock motor with just bolt ons and a 150 shot, i think.
Old Sep 16, 2004 | 11:49 PM
94-3.4's Avatar
It is a lt1, did a swap a few years back from the 3.4.
Old Sep 17, 2004 | 03:26 AM
Derrick Redd's Avatar
I hit mine WOT from idle. I do have a 3,600 stall that flashes to 4k on the dope though. Do you have a large stall? I wouldn't spray from idle with a stock torque converter. JMO.
Old Sep 17, 2004 | 09:00 AM
94-3.4's Avatar
I have a 2800 yank, i would say it flashes 2400 or so n/a so maybe it will flash higher on the nitrous.
Old Sep 17, 2004 | 11:53 AM
BIGBADBOWTIE's Avatar
Just an FYI Derrick, I run a 9" 3500 stall that flashes to about 4200 on the bottle(125). I usually try and get up on the converter a little when making a nitrous pass. A few weeks back I had a bad case of brainfart-itis and did nt get on the converter and basicly nail it from Idle...... BOOM!! The car hickuped, bucked a few times and made a nice flame show. The boom was big enough that it took one of the butterfly (850 holley) screws and almost put it clean through the top of my airfilter assembly. Lots of damage..
long story short....but be careful...it was not a cheap fix.
Old Sep 17, 2004 | 04:42 PM
Sunsceamer's Avatar
Maybe try a low shot like 50 at 2500 will be safe see how the convertor handles it. Do a night or 2 off test and tunes with this. Best thing to do is get use to it so than you can glance at the tack and see what it can do. Than up to 75 test a while and if it likes it you could go to 100. I just dont recomend 150 below 3 thousand. Some old schoolers claim not below 3500 because it is a hell of alot of spray per cylnder at low RPM. I wouldnt go more than 100 rwhp at 2400. You could do a 2 stage.
Old Sep 19, 2004 | 10:57 PM
n20ta2's Avatar
im spraying a 250 shot off the line,I have a 3500 stall and a transbrake so i stall to about 4000 actual rpm against the 'brake.Im also running a celonoid that inturupts the nitrous when the transbrake is activated so I can hold the steering wheel nitrous button down and when the trans brake is released it starts spraying immediatly.Im running some big rear tires though 28x12.50 e/t streets on draglights.
Old Sep 20, 2004 | 01:38 PM
95zzz28's Avatar
i plan on spraying of the line w/wot switch. i am only going to spray a 100 though. i am going to feather it for a little bit and then romp on it.
Old Sep 20, 2004 | 09:04 PM
mrr23's Avatar
this is how i do mine. i use a WOT switch. i launch the power (arming switch) off. then at 2k rpm, i turn on the power. then at the end of the run, or if i spin, i just let off the pedal and the WOT switch cuts power to the solenoids. cheap window switch if i ever saw one.
Old Sep 21, 2004 | 11:34 AM
JucinGTA's Avatar
I spray 200 out of the hole. Trans setup is a 3400 stall, 10 bolt 3.73
Heres a pic.
http://www.ugsr.com/upload/showthrea...2&pagenumber=3
Old Sep 23, 2004 | 03:28 PM
kostya_f's Avatar
A window switch would be good insurance in case your transmission decides not to shift.
