LCA Install
Old Sep 11, 2004 | 11:56 PM
LetMeBurnU's Avatar
LCA Install
How hard is it to install LCA's?? Will i also have to get the relocation bracket and also my car is not lowered.
Old Sep 12, 2004 | 12:03 AM
Z95m6's Avatar
Re: LCA Install
if you get the LCA's you should probably get relocation brackets. I would say you should probably be able to install bolt on relocation brackets and LCA's in 1-2hrs.
Old Sep 12, 2004 | 12:39 AM
Xride's Avatar
Re: LCA Install
it should take MAX 30 minutes to change the LCA's and to add relocation brakets at the same time should be 10 more mines MAX.
Old Sep 12, 2004 | 10:24 AM
Jeffw's Avatar
Re: LCA Install
installing lca is easy do one side at a time and support the rear axle simple bolt in and out operation. relocation brackets require welding if you don't have access to a welder it will make this imposible to do simple. you will need to pull the rear and take to be welded, you CAN NOT bolt in lca relocation brackets. you don't really need them either unless you have alot of wheel hop. since you are not lowered.reloc brackets do 2 things help realing pinion angle after lowering springs and reduce wheel hop.
Old Sep 12, 2004 | 12:14 PM
Xride's Avatar
Re: LCA Install
WRONG
You CAN get bolt in relocation brakets, and in some cases are BETTER then welding them in, but it depends what your doing with you car.
Also, they help reduce wheel hope [b]BEACUASE[/b} they correct instant center.
When stock hight they will still help, but put it in the higher hole.
Old Sep 12, 2004 | 01:10 PM
LetMeBurnU's Avatar
Re: LCA Install
I think I'll just stick to the LCA's and stick to my stock brackets. Will i need the new relocation brackets if i lower my car later on...?
Old Sep 12, 2004 | 01:25 PM
Xride's Avatar
Re: LCA Install
Please dont listen to Jeffw, he doesnt know what he is talking about.
just LCA's will help, esspeicial in stock trim still.
you can always get the relocation brakets later, its best to phone the company that makes the ones you wnt and ask them if the welded or bolted is best for your aplication.
Old Sep 12, 2004 | 03:18 PM
Z95m6's Avatar
Re: LCA Install
There are bolt on Relocation brackets. Most people don't get them though because they are more expensive. I have bolt on ones i got off the board here pretty cheap. I've heard you want your LCA's to be running parallel to the ground for the best traction. Mine with out LCA's went like this / obviously not that radical but the rear end side was higher than the body side. Thats why i got relocation brackets. So i guess its how your car sits.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
Apr 30, 2015 03:43 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
