Poly bushings recommendations
Old Sep 8, 2004 | 03:37 PM
andysc's Avatar
I gotta replace my lower control arm bushings, and want to go with polyurethane bushings. So there are Prothane or Energy suspension. Which is better or is are rubber better. Looking for some good info.
tia
andy schuck
Old Sep 8, 2004 | 05:08 PM
Xride's Avatar
Re: Poly bushings recommendations
depends what you search feature brings up...
anyways, they are the same go with whatever brand your local place has, mine has energy so thats what I got.
For LCA if you go poly and poly you could get some bind if you are hard in the corners, and might get noise (I didnt from poly poly) but you can get a poly on the car side and rubber on the axel side. as a comprimise.
Old Sep 8, 2004 | 11:00 PM
OBE1 95Z28's Avatar
I bought the ES front control arm rebuild kit and only used the upper control arm bushings as I ended up buying BMR lower control arms that come with the bushings installed. I'll sell you the lower control arm bushings for $40 shipped. Shoot me a PM if interested.
Old Sep 9, 2004 | 02:48 PM
Mtrhds94Z's Avatar
If the above is correct, I put mine in 'backwards'...[rubber to car end]
See also:
http://web.camaross.com/forums/showt...=poly%2Frubber
So which is it? Rubber to car end or axle housing end?
Charlie
Old Sep 9, 2004 | 03:00 PM
OBE1 95Z28's Avatar
The poly or rubber end mounts to the axle per Global West's site.
Old Sep 9, 2004 | 03:02 PM
OBE1 95Z28's Avatar
Let me clarify, the stiffer material (poly) mounts to the axle, the flexible piece (rubber or sperical bearing) mounts to the body.
Old Sep 9, 2004 | 06:09 PM
Xride's Avatar
Ok that sounds right after reading it.
I thought it was the other way though. Thanks for clarifing.
Old Sep 9, 2004 | 11:35 PM
Mtrhds94Z's Avatar
OK, I feel better now...lmao
Rubber to frame.. Poly to axle housing..
Thanks!
Charlie
Mar 13, 2016 03:37 PM
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
