need someone to listen to my engine
Old Sep 1, 2004 | 12:52 PM
1994TransAm's Avatar
hi guys,
i just started up my new 355, it has a gm 847 cam, lloyd elloit heads, 1.5cc rockers, new pushrods, comp r's, stock rods stock crank, speed pro pistons.
i started the car up to break it in and i have some major concerns,
first off : car holds an idel and i only have code 16, my o2 read fine and i have a good tune for the car, i'm getting a very small knocking noise from the engine but i cant tell where, or why its there.when i drained the oil everything looked fine... some metal on the top, but nothing that would pick up with a magnet.
secondly: i dont have any knock retard showing... even at 3k... i havent reved past that yet, but i'm wondering if the knock i'm hearing is the rockers... i havent adjusted them totally... but the noise i herd was different than a tick... wouldnt the KS pick up a knock?
can anyone come out to hear the engine..i'll pay yea for your help
Old Sep 2, 2004 | 04:44 AM
AL SS590 M6's Avatar
Re: need someone to listen to my engine
Originally Posted by 1994TransAm
hi guys,
comp r's
How did you adjust these?? Don't adjust them too deep. Just zero lash plus 1/16-1/8 turn.
Old Sep 2, 2004 | 06:52 AM
Timberwolf's Avatar
double check your firing order too. one crossed wire and it will still run, but make a nasty knock. It's easy to confuse them when routing from the opti to the plugs
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Nov 23, 2014 10:33 AM
