1994 v6 with 98-02 frontend , ttop conversion and firebird dash and door panels
Old Aug 25, 2004 | 10:43 PM
KevsKooLKamaro's Avatar
1994 camarov6 with 98-02 frontend , ttop conversion and firebird dash , door panels
http://kweems.photosite.com/ check it out let me know what you all think.theres alot of pics over 60 i think if anyone wants diffrent angles of the work ive done just ask i dont mind takeing pictures ......right now im still working on the shaved door handles with school and work not alot of time to work on the maro but honestly takeing my time on it has made all the work ive done better , do it right the first time i guess is the way im looking at it
later people
kev
Old Aug 26, 2004 | 09:00 AM
ProjectCamaro's Avatar
Re: 1994 v6 with 98-02 frontend , ttop conversion and firebird dash and door panels
Wow, that looks really good.
Old Aug 26, 2004 | 12:01 PM
thanks man
kev
Old Aug 26, 2004 | 02:09 PM
hey can you guys see the pics ?? if you can there not best of quality , ill try to get better pics up soon
Old Aug 26, 2004 | 07:50 PM
96Black RS's Avatar
Looks great It's good to see someone doing someting different with their 4th gen. than the same old stuff.
Old Aug 26, 2004 | 07:56 PM
crazyjim thats cool hate it , as of right now i have 3500 bucks into it , doing all the work myself and my bro working at a salvage yard .........im getting a 98 z28 drop top when this is done , this car is just for fun but one thing your right on is it would be a waste if you wernt getting the parts bellow coast, ill do a few performance mods over the winter , theres not a whole lot you can do with a 3.4 , this car is all show no go kinda sad
kev
Old Aug 26, 2004 | 09:43 PM
honestly the car needs to be painted looks good with some water on it lol , i have it sanded down right now once i get the the popper kit for the shaved doors , i can finsh it off with a new paint job .....but if anyone has any questions about anything i can try to help you as best as possible with pics , cause if it wernt for this camaro site i wouldnt have done anything
kev
Old Aug 26, 2004 | 09:51 PM
Kyle@CSS's Avatar
Can the TA panels work in a camaro without changing the dash?
Old Aug 26, 2004 | 09:57 PM
yes they will !
Old Aug 28, 2004 | 10:38 AM
TheV6Bird's Avatar
At least your honest and not pretending like it is
I'm not a fan of that hood...It just blantanly sticks out on a Camaro.
Everything else looks great though, especially the grill
Old Aug 28, 2004 | 07:54 PM
camaros_4_lfe's Avatar
im likin it allot good job so far
Old Aug 28, 2004 | 10:38 PM
chevroletfreak's Avatar
Very nice conversions and mods
What did you use to fill in the door handles and antenna?
Also, did you have to do some rewireing to use the TA panels?
Old Aug 28, 2004 | 11:52 PM
ok for the door handles and antenna , i used light weight bondo . heres the trick with the door handles , you want to grind the edge down were the door handle was so you will have to feather out the bondo , if your just filling in the hole , it will crack out also make sure you put the bondo in thin layers so it fills even .after the bondo work is done , i did some sanding useing this tool that has a handle on it , that is a must for getting the bondo work to blend with the rest of the door .after the bondo i ussed a fill in primer then a little more sanding and some bondo glaze , not the orange crap the stuf that you mix the hardener , then a little more primmer and some wet sanding , its ready for paint ,the antenna i used some of that bondo scren and some lightweight sanded it down.................ill get more pics up of this later you wuill see what im talkking about the only rewireing on the trans am doors is on the rear view mirror switch , everything else plugs in normal
hope this helps a little , ill get some more pics up
kev
Old Aug 29, 2004 | 09:17 PM
Bawls's Avatar
Looks damn good man. Pretty much everything I was going to do with my 94 z28. Firebird interior, LS1 frontend. ttops. But I sold her about a year ago, and just recently bought a 94 firebird formula w/ttops
Old Aug 29, 2004 | 11:34 PM
thanks man , so far the hardest thing to do ont this camaro was putting that damn aftermarket hood on , it took me a few days to get it right ......it still needs a little more work on the driverside and it should be as good as you can get it , thanks for them comments , also i added a few random pics through out the photo album
kev
