Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Affordable LS1 rotating assemblies are just around the corner!
Old Aug 6, 2004 | 09:47 PM
tbyrne's Avatar
SLP is putting together some low cost but high quality rotating assemblies that can be used with GM's LQ9 iron 6.0-liter block. 383 and 402 cubic inch displacements will be available. Here is a quick rundown of what they are producing and what we will have to offer -
ZL 383 - low compression -
4.000" 4340 forged steel crankshaft, balanced to rotating assembly
3.899" heavy-duty, high-compression 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
383-CID displacement
9:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for forced-induction applications
Includes new rod and crank main bearings
ZL 383 - high compression -
3.899" 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
10.8:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for naturally aspirated applications
ZL 402 - low compression -
6.125" I-beam rods
ZL 402 high compression -
6.125" I-beam rods
More details for each of these can be found on our website. Pricing for each kit is $2499.99. We're currently taking pre-orders and should be able to start shipping around the 1st of September.
Old Aug 7, 2004 | 10:57 AM
tbyrne's Avatar
Re: Affordable LS1 rotating assemblies are just around the corner!
Typo alert!
It should have said -
ZL 402 - high compression -
4.000" 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
402-CID displacement
11.3:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
and
4.000" heavy-duty, low-compression, 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
mrwz28
Jul 8, 2015 09:11 PM
CARiD
Jul 7, 2015 08:19 AM
camaro02DK
Jul 5, 2015 09:04 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
