tuning a SC in '93
Old Aug 3, 2004 | 08:33 AM
donot_4get's Avatar
tuning a SC in a '93
I think I read that a FMU might actually be a better option for '93 becuase of the Speed Density syst. (intead of MAF) ... is it true???
Anyway,
What would I need to make my life esier when tuning a p600B in my 93
thanks
leo
Old Aug 3, 2004 | 09:24 AM
IDOXLR8's Avatar
Re: tuning a SC in '93
Anyway,
thanks
leo
Tuning is the key to making your stock motor last. On a supercharged application I recommend getting it dynotuned. Mail order dynotunes are ok but not something I would rely on if you plan on making alot of visits to the track.
I was running an FMU, 24lb injectors and a mail order tune with my P600b. My car did run on the rich side which I blame on the poor mail order tune. I guess it is better to run rich than lean.
Old Aug 3, 2004 | 04:45 PM
LJ93Z28GM's Avatar
Just got my P600 so when I get some time I have to put it on my 93. What do I need to change, I did not get the whole kit new from ATI, I just got a headunit from a buddy as well as the FMU and some 30lb injectors. My car already has an inline 255 pump.
Is the stock MAP sensor okay. Do you think I will need to intercool 6lbs of boost?
Old Aug 4, 2004 | 05:49 AM
IDOXLR8's Avatar
6lbs is ok for a non-intercooled system and the stock map sensor is ok.
Old Aug 4, 2004 | 03:37 PM
LJ93Z28GM's Avatar
Either way I am going to intercool the setup just to make sure. I really do not want to go through a rebuild again at this point, but it is good to hear that I really do not have any other unseen formalities.
Old Aug 5, 2004 | 06:35 AM
IDOXLR8's Avatar
The problem is that supercharged applications are tempermental. Some people go years before rebuilds while others go a few hours. I would say the most critical things are a good tune and good fuel. Tou bad 93's do not have the capabilities to run a scanmaster.
Old Aug 5, 2004 | 11:24 AM
toryblownss's Avatar
If your in S.C. go to Jeff at Carolina Auto Masters. I had a mail order tune on my vortech and it caused an early death.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
