advise on 1 farad capacitors...found this one on eBay...
Old Aug 2, 2004 | 08:26 PM
Somnambulist's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...712210960&rd=1
This didn't look to bad. What would you advise to run between one 4 channel amp and one mono amp?
Old Aug 2, 2004 | 08:38 PM
97FormulaWS-6's Avatar
Re: advise on 1 farad capacitors...found this one on eBay...
What size amps?
I'm running 2 1-Farad Voodoo caps on my main power line feeding a 400Wrms 4ch, and a 1600Wrms subwoofer amp. Most of the time it's fine, but I still get a mild case of dimming at some stop lights if the volume is above 25/35.
Old Aug 2, 2004 | 09:49 PM
LS1 RULZ's Avatar
Before you go throwing money away on a cap make a couple of upgrades to the factory wiring first. Replace the tiny ground wire with a section of 4AWG like I have in this photo. Also replace the +12V cable going across to the other side of the engine bay.
http://pic5.picturetrail.com/VOL83/5...8/62070357.jpg
This is the other end of the +12V cable upgrade.
http://pic5.picturetrail.com/VOL83/5...8/62070336.jpg
Old Aug 2, 2004 | 09:54 PM
I already have updated wiring all around from the big Rockford amp kit...
Old Aug 2, 2004 | 09:56 PM
one 700W V12 mono and one 500W V12 4-channel amp...
Old Aug 2, 2004 | 10:18 PM
LS1 RULZ's Avatar
If you get the cap try to mount it as close to your subwoofer amp as possible. This is where it will do the most good. Since the bass places the highest current demands on the car's charging system the closer the cap is to the subwoofer amp the better.
Old Aug 2, 2004 | 10:28 PM
cool thanks
Old Aug 3, 2004 | 01:36 AM
crasher88's Avatar
All I'm gonna tell you is to be careful. Don't know how knowelagable you are in electronics but a 1 farad capacitor is very powerful and could easily kill a few grown men with one shock.
Old Aug 3, 2004 | 06:31 AM
Good point, I forgot to mention that. I've got about 18" of wire between my cap and my 2 amps.
Old Aug 3, 2004 | 02:41 PM
im also not a 16 year old kid, but thanks...
93 RedBird
Nov 15, 2015 08:24 AM
Bobczar
Oct 23, 2015 11:22 AM
drt
Sep 27, 2015 04:39 PM
canuck94z28
Aug 19, 2015 05:50 PM
Trans-Am
Nov 21, 2002 06:56 PM
