1LE Panhard rod
Old Jul 27, 2004 | 06:53 AM
BiGGinZ's Avatar
1LE Panhard rod
Would a 1LE Panhard rod be any improvment over the stocker? I know there could be better improvment with other peices but just looking for a little better handling for everday driving, thanks.
Old Jul 27, 2004 | 08:41 AM
Red96Lt1's Avatar
Re: 1LE Panhard rod
You will probably see very little difference till you hit the corners hard.
Old Jul 27, 2004 | 11:22 AM
LT4Firehawk's Avatar
Re: 1LE Panhard rod
1LE panhard rod is just a stock bar with harder bushings. Skip it and go for a double adjustable rod-end panhard bar if you are going to upgrade. This was my choice for a bar (and I had the 1LE unit):
http://www.unbalancedengineering.com/Camaro/PHR/
Old Jul 27, 2004 | 02:46 PM
O-taka's Avatar
Re: 1LE Panhard rod
that's nice
i could feel a diff going from the 1LE weak stamped panhard to a BMR double adj, not rod end, just poly. needed if you go to 315s rear
Old Jul 28, 2004 | 11:26 AM
teke184's Avatar
Re: 1LE Panhard rod
for the $90 or so they cost, you may as well just get the BMR poly bushing PHB ...
there was even a 15% discount in the group purchase forum that i think is still going on.
makes it really worth it
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
KYWes
Aug 10, 2015 07:03 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
