1LE Suspension
Old Jul 25, 2004 | 10:18 PM
Kataklysm's Avatar
1LE Suspension
Exactly how much better is the 1LE suspension over stock? I currently have bilsteins and the SLP springs that came on the car. Would I see any improvment? Thanks for info.
Old Jul 26, 2004 | 06:54 AM
teke184's Avatar
Re: 1LE Suspension
i think your setup is pretty similar suspension wise. the bushings may not be the stiffer 1LE versions but the SLP springs and Bilsteins are probably as stiff or stiffer than the 1LE.
for the money i don't think you'd notice anything.
i would spend it on a real upgrade...like the BMR 32/21mm swaybar kit or the susp tech 35mm front bar.
also some lca and phb would be a good addition
Old Jul 26, 2004 | 10:08 AM
Hyperspeed97z28's Avatar
Re: 1LE Suspension
Your current setup is better then the 1LE setup..
Old Jul 26, 2004 | 10:21 AM
Camaro_Maniac63's Avatar
Re: 1LE Suspension
What do you not like about your current setup as far as handling goes? If we know what you want to do with the car, we might be able to help out a little better.
Old Jul 26, 2004 | 07:19 PM
Kataklysm's Avatar
Re: 1LE Suspension
It handles very well, great cornering (I have SFC, STB, PHB, LCA and hawks had bigger sway bars) but it rides like crap...only has 55k but the shocks are 9 years old! I was just curious since I could get the whole 1LE setup new for the price new bilsteins alone are gonna cost me.
Old Jul 26, 2004 | 08:03 PM
Re: 1LE Suspension
If you want a cushier ride, go with the KYB Gas-a-Just shocks. Not very good shocks as far as handling goes, but my car rides very good with them. Bilsteins seem to be a very good compromise between ride comfort and handling, however.
Kinglouui
May 26, 2016 11:05 AM
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
