Throw out bearing bad?
Old Jul 23, 2004 | 12:38 PM
Roadart's Avatar
Hello all, I was wondering how you can tell if a throw-out bearing is bad.
When I start the car, I can hear a slight whine that goes away when I push in the clutch pedal.
I have also begin to notice a very small (about the size of a silver dollar) puddle under the trans (where it bolts to the engine). I thought it was oil at first, but I think its clutch fluid because I checked the master cyclinder and it was low (about 1/4 the way down).
I have the SLP Lightweight flywheel, SLP LT4 Clutch and PP /w throw out bearing. About 3000 miles on the clutch setup, and new Master/Slave unit from GM.
If I am leaking fluid, will that damage the clutch setup? The clutch doesn't slip, and I noticed the leak about a month ago but I don't drive the car often.
Thanks Guys,
Kevin
timmy39120
May 2, 2015 05:12 PM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
grabbem88
Feb 17, 2015 07:49 AM
HectorM52
Jan 30, 2015 11:08 PM
