rod orientation?
Old Jul 21, 2004 | 07:08 PM
94zrag's Avatar
rod orientation?
I apologize if this isn't advanced enough for advanced tech, but I couldn't find info anywhere else. I bought some eagle forged 5.7" h-beam rods, and one of my friends told me that it's possible to install them backwards because of the location of the oil passages. Is this true? If so, what's the proper way to install them? any help would be great, thanks.
Old Jul 21, 2004 | 07:52 PM
Stephen 87 IROC's Avatar
Re: rod orientation?
If you look at the bearing part of the rod you'll see a chamfer on one side. The chamfer goes against the fillet on the crank (curved radius). The side without the chamfer goes against the other con rod on the same journal.
Old Jul 22, 2004 | 07:11 AM
Zero_to_69's Avatar
You'll know if you have it wrong when you install and torque the bottom end.
The rotating assembly will lock if the chamfer and fillet are not mated.
It's always a good idea to spin the crankshaft after doing the torque sequence on each rod, cap, etc.
Old Jul 22, 2004 | 04:25 PM
Revolutionary's Avatar
The mantra I recite when assembling pistons on rod is - tang to the dome, tang to the dome, tang to the dome....
the bearing tang on the rod is on the same side as the dome on the piston ( which is the exhaust side if you dont have a dome)
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
