ABSINOP light came on!!! help!
Old Jul 19, 2004 | 04:00 AM
crAzy95z28's Avatar
ok can i get a lt1edit or scanner to look up this code? if not then i know it has to be coming from the rear, bc my passenger side rear axel is leaking fuild...i think its my axel seal, cause i replaced my axel not to long ago but never replaced the seal which i should have...would that cause the ABSINOP light to come on? or would somehting else cause that in my brake system?
or would i be able to get is scanned and find out what the problem is?
please let me know ASAP....
im changing my seals tom...and getting royal purple, and would i need some extra additive or i can just use royal purple?
Randy
Old Jul 19, 2004 | 06:45 AM
IllusionalTA's Avatar
Re: ABSINOP light came on!!! help!
Your axle seal would only affect things if you had a 4channel system.. Only car's that have traction control have them.. SO i'm guessing your rear sensor is on top of your rear end pumpkin.. Get's its signal from a reluctor thats onthe diff... I don't think you can read abs code's through edit.. I think a Tech II from GM or possibly autozone might be able to pull the abs code's not sure.. Check your brake fluid, too low a charge on the battery will affect it as well.. Check the sensor's behind the front wheel hub's.. Otherwise forget about it.. If you need it.. It's too late!!
Old Jul 19, 2004 | 06:57 AM
crAzy95z28's Avatar
im thinking some of the rear fluid could be dripping on one of the sensors back there and causing it not to read!!!
Old Jul 29, 2004 | 04:32 PM
camarochick350's Avatar
I had my ABS light come on not that long ago..... Try taking the relay out and lightly tap it against something then re seat it. It worked for me for a while but I eventually had to replace the relay. Hope this helps somewhat
Old Jul 29, 2004 | 04:34 PM
the actual sensor is in the top of the rear end.. designed to get WET!...
Old Jul 29, 2004 | 04:35 PM
I doubt it would be the sensors at all. Before I replaced my relay I had checked all the sensors and it didnt change a thing.
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
