anyone ever reinforced their stock Torque arm?
Old Sep 25, 2002 | 01:41 AM
blksgZ28's Avatar
how would I go about reinforcing my stock torque arm? What thickness sheet metal, what kind of sheet metal, where do I weld, etc. Anyone have a picture of a boxed/reinforced Torque arm?
Old Sep 25, 2002 | 08:55 AM
MattSLONOMO's Avatar
when the NHRA stockers were still required to use "stock"
torque arms...they welded two together..
some welded Moly tubing to it..no pics..just what I remember seein'..
hope this helps..
Matt
Old Sep 25, 2002 | 11:43 PM
mod313's Avatar
I reinforced my original torque arm. I used a length of 1/4 thk x 2" flat bar and ran it for most of length of lower part of the arm. At same time I also relocated the front mount to the body.
Old Sep 26, 2002 | 01:02 AM
Daddyo's Avatar
How did you mount it to the car? If you have pic's please share them with me.
Thank you
Old Sep 26, 2002 | 01:07 AM
TobyZ28's Avatar
Arrow
Can someone explain how it works? I know it has something to do with exerting force downward to the ground through the tires... but how? =)
Old Sep 26, 2002 | 01:17 AM
Z4 Performance97's Avatar
Hope some of yall have some pics!!!!!!
Old Sep 26, 2002 | 01:29 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Heh... Both Jordon Musser and myself welded flat washers to the mounting holes and it works ... Haven't broken another stock arm - and it's been months!! <- it's a record
Old Sep 26, 2002 | 02:09 AM
blksgZ28's Avatar
i'm under the impression that jordan has made all his passes on his original torque arm, adn rather than shell out ~$500 for an aftermarket one, I want to reinforce mine.
if his can take 500+ hp, it could certainly handle my measly $350 hp.
Old Sep 26, 2002 | 09:59 AM
ANY PICS??
Old Sep 26, 2002 | 10:05 AM
Jason Short's Avatar
500+? More like 700rw I am planning on doing exactly what Shawn and Jordon did to their T/A myself.
Jason
Old Sep 26, 2002 | 10:24 AM
dougg01's Avatar
I want to see pics of how folks moved their torque arm mount off the tranny....
I have some ideas.....but I'd like to see what others have done. I think slonomo did something like this to his once.
What I'd really like to see are pics and data on a 4th-gen stocker's setup....
Old Sep 26, 2002 | 11:35 AM
Daddyo's Avatar
Like I said up there. I too would like to see some pic's. I also have an idea of what I want to do but would like to see what others have done.
Old Sep 26, 2002 | 06:16 PM
mod313's Avatar
Sorry, no pics. What I did was lay the flat bar along the lower section of the arm and just tip it in which formed the "box". As far as the front mount set up. I just made up a couple brackets from flat stock I had and did what I had to to mount them to the body and then position the front location of the arm with the suspension at normal ride height.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
