rocker arms
Old Jul 12, 2004 | 09:43 AM
jasonss's Avatar
rocker arms
trying to find me some rocker arms, comp shows some, with 5/16 or 3/8 guides plate which one does my car have its a 2000 or does it matter
Old Jul 12, 2004 | 10:40 AM
teke184's Avatar
look into the yella terra pieces from thunderracing...they are shaft mounted in pairs, not requireing guide plates and are about $500 i think...
i've been researching them too.
Old Jul 12, 2004 | 01:00 PM
jasonss's Avatar
are those good rockers, do they have a good reputation
Old Jul 12, 2004 | 05:07 PM
teke184's Avatar
i've been hearing good things about the yella terras
Old Jul 12, 2004 | 05:29 PM
SSpdDmon's Avatar
I'm pretty sure stock is 5/16 in diameter.
Old Jul 12, 2004 | 05:40 PM
mrr23's Avatar
5/16 is stock diameter. i use the VHP 1.89 accelerated rocker kit. http://www.vincihighperformance.com/superwebdeals.HTML
i also had them install their dual spring kit at the same time. here's the dyno results:
hp graph
tq graph
this was with no tuning. this is on the 99 formula in my sig.
Old Jul 12, 2004 | 08:14 PM
teke184's Avatar
that's alot of freakin torque!!!
i kindda quickly added up what would be needed...and it easily tips the scales at $750
that's alot!
Old Jul 13, 2004 | 04:26 PM
mrr23's Avatar
sorry. but, it wasn't alot of torque. if you look at the left side of the red graph, there is a spike. that's a fluke that sometimes happens. there was a 13 lbs-ft gain. that's why i put the cursor on the graph to show the real gain.
Old Jul 13, 2004 | 04:46 PM
J0HN D's Avatar
I like the Harland Sharps.
Old Jul 14, 2004 | 01:17 PM
Greed4Speed's Avatar
Out of the six 10 sec LS1's in the article in GMHTP, 3 of them ran stock rockers. Save that $750 and get you a cam, headers or something that'll actually help you.
Old Jul 15, 2004 | 08:03 AM
jasonss's Avatar
this is a heads and cam car with headers, getting rebuilt, i was gonna put some good ones in because they have problems with needles being found in the oil pan
Old Jul 15, 2004 | 11:58 AM
Those cars I mentioned have heads and pretty large cams. They run 10s, that should tell you someting.
Old Jul 16, 2004 | 01:29 AM
AL SS590 M6's Avatar
I went with the Comp Cams Pro magnum 5/16" guide plate rockers, primarily because they are the cheapest way to get adjustable rockers on an LS1. I'm running Comp 'r' lifters and they are fussy about preload.
Old Jul 18, 2004 | 03:07 PM
jasonss's Avatar
which one's would be better the 5/16 or the 3/8
Old Jul 19, 2004 | 02:04 AM
Re: rocker arms
You have to match your pushrods. LS1s have 5/16 pushrods.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
