streaks with Z-6
Old Jul 10, 2004 | 07:18 PM
GoFast908Z's Avatar
Member
streaks with Z-6
I'm a 3 year zaino user and use it in detailing customer's cars. But I always have a problem with streaking with the Z-6 spray. I have to do it over and over to eliminate streaks. I've tried it with it in the shade and in cool temps, also in the sun when its hot. No matter what conditions, it streaks. I use the fieldcrest towells too. Whats the problem?
Old Jul 10, 2004 | 07:33 PM
Zaino guy's Avatar
Maybe your using too much? try smaller amounts.
Old Jul 10, 2004 | 07:35 PM
GoFast908Z's Avatar
Member
I do use small amounts. I like to conserve it. Besides, like with the rest of zaino, a little goes a long way.
Old Jul 10, 2004 | 08:48 PM
SSMOKEDU
Guest
Posts: n/a
I just read this on Zaino's site.
Using Z6, you're supposed to use an amount, about the size of a dime, per square foot. It is also suggested that you could try and use a 50/50 mix of Z6/water. Check out their site for alot of helpful tips.
I just think you may be using too much.
Old Jul 11, 2004 | 03:10 AM
GoFast908Z's Avatar
Member
50/50 mix huh? Hmmm. Haven't heard that before. I'll give it a try tomorrow when I wash my car. Thanks
Old Jul 11, 2004 | 07:42 AM
jeepbeast's Avatar
i just posted the same question a few weeks back. what i did was use the 50/50 mix with water and no more streaks
Old Jul 11, 2004 | 08:30 AM
Error's Avatar
I've been using the 50/50 method for a long time. Make sure you use distilled water though.
Old Jul 12, 2004 | 03:21 AM
GoFast908Z's Avatar
Member
so, i'm guessing, no tap water then?
Old Jul 12, 2004 | 08:51 AM
KevinSS's Avatar
Just sprinkle the surface with Z-6, no dousing, wipe the product around evenly with a clean towel, flip the towel to the dry side and it will evaporate evenly and one more pass with the towel and it should be perfect....
Old Jul 12, 2004 | 03:06 PM
GoFast908Z's Avatar
Member
Am I just retarded? Cuz that is what I've been doing all along, small amounts, sprinkle, clean cloth, flip, re-wipe, but it still doesn't work.
Old Jul 12, 2004 | 03:57 PM
SSMOKEDU
Guest
Posts: n/a
You're not retarded.
Just another idea, but I always make sure to really shake up the Z6 before using. I'm just grasping at straws for ideas as to why youre having a difficult time
Give the 50/50 mix a try
Old Jul 12, 2004 | 05:52 PM
Kevin V 2002 SS's Avatar
It is also easier to spray the towel instead of the surface, especially if the surface is hot.
Old Jul 12, 2004 | 06:01 PM
Cmr0z28's Avatar
The purpose of a QD spray is to lift light dust off of the paint surface for cleaning, to keep it looking good between washings. This is why you spray it ON the paint....so it lifts the dust off, so that it doesn't induce marring when you wipe it off.
Old Jul 14, 2004 | 11:57 AM
)2overt SS's Avatar
Try rubbing it quickly, I found that to help some. Also, spray it on and rub around in an area and if it is not rubbing it, "spread" it out more, if you know what I mean by that.
Old Jul 14, 2004 | 02:32 PM
Buffy's Avatar
i use 50/50 with my tap water and haven't had any problems so far.
nophix
Nov 30, 2014 10:26 PM
JeffB_94Z
13
Jul 25, 2003 03:34 PM
99blackz99
Jul 7, 2003 07:52 AM
Wildcat
11
Mar 24, 2002 11:52 AM
JSK333
Sep 22, 2001 07:50 PM
