ported heads with nitrous?
Old Jun 30, 2004 | 12:47 AM
96birdlt1's Avatar
Is it true that ported heads don't need to flow as much on the intake side when using a power adder such as nitrous as long as the exhaust has good flow numbers?
Any help would be greatly appreciated
Thanks
Joe
Old Jun 30, 2004 | 12:56 AM
12Second3rdgen's Avatar
Re: ported heads with nitrous?
Thanks
Joe
Yes. In a lot of the David Vizard books he talks about being able to make in excess of 175 horsepower with 100 horsepower nitrous jetting just by doing exhaust related mods. Just keep in mind the motor will be a dog off the bottle with a lot of these mods (1.5's on the intake, 1.6's on the exhaust, tight lobe separation, 13* or more exhaust duration than intake @.050, etc, etc.
Old Jun 30, 2004 | 01:23 AM
96birdlt1's Avatar
These heads flow 235 on the intake and I forget what they flow on the exhaust side, but it is similar to most flow numbers I have seen on the web. I'm sure that there is some performance to be gained off the bottle, and I am giong to use the CC305 cam. These heads aren't bad are they?
Thanks
Joe
Old Jun 30, 2004 | 09:18 AM
You would want them to flow somewhere around 175cfm on the exhaust side to achieve a .75 I/E ratio. They arent bad, there are people making good power with vortec heads and that is right around what they flow on the intake side.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Wilson
Jul 21, 2002 05:08 PM
