06-29-2004, 10:49 PM
383/396 guys inside, post your NUMBERS
I am looking into doing a stocker eng in the furture and would like to see the diff combos that are out there,
What you have done to the short block, ie:rods,crank,pistions,ring, bearings,oil pump ,oil pain
Top end ie: heads,cam,intake
What RPM are you turing.....any and more info would be great.
thx
06-29-2004, 10:59 PM
__________________
97 Formula with Bauer Racing built 383" - ARP - Scat 9000 Crank, 4340 I-Beams – SRP Pistons
11.3:1 Compression - Canton Pan - Advanced Induction "Full Port" Heads - "AI" Cam - Comp "R" Lifters
Comp Pro Mag RR's - Cloyes True Roller - 42#/hr Racetronix Injectors - AS&M 58MM TB
"Bret"  ported Intake - No AIR or EGR - Jet Hot LT’s - Jet Hot O/R Y-Pipe - Magnaflow Cat-Back
CSI Elec. W/P - Delteq Ignition - OBD-I Conversion & Tune (MadWolf) - BMR K-Member, D/S Loop, SFC's, STB; etc. etc.
06-30-2004, 12:14 AM
This is actually a good point. Peak #'s mean nothing, its the curve that you need and the rest of the combination. But anyway, back to the thread now.
__________________
1996 Formula--stock heads/cam, RealQuicks hot parts, T76 ..10.80 at 127.8 now sold www.lt1boost.net
2008 TrailBlazer ss - 12.34 at 108 ONLY bolt ons!
1983 rx7 - 2560lbs, 9.93 at 144.7, 5.3/tc78, budget build
06-30-2004, 12:18 AM
Dave--Ya got that right--HEE HEE
06-30-2004, 12:24 AM
Maybe he meant 'part #s' of the guts of the motor.
06-30-2004, 06:11 AM
Re: .
Quote:
Well...in that case I can help out with that too
This is the latest one, need to update a few parts:
http://paradox.shacknet.nu/dave88lx/formula/383/383.htm
Depending on the year of your car some parts may be different. (Gaskets & seals)
__________________
06-30-2004, 01:05 PM
Nice spreadsheet and information, Dave. Your list represents the 'reality' of all the little things that tend to add up fast. Throwing a lot of parts at that car at once. Should run great, and it looks like you did your homework.
Didn't see the valvesprings accounted for though? Probably in another line item.
06-30-2004, 01:15 PM
383 stroker. AFR 190cc heads, 6" rods, bored .040 over, so it's actually a 386 rather, or close to it. Dimond pistons, milled heads, and ported intake, 285cfm at .550 288 @~.600
Dynoed 396.6 @ 6050rpm and 396fptq @ 4900rpm on a Mustang Dyno, or about 420rwhp on a dyno jet.
Custom ground cam.
__________________
2002 Z06
2001 ZR2
1996 Z28 383 Stroker
06-30-2004, 01:17 PM
Thanks man, I learned this game can dollar you to death!
It's easy to say "Aww, crank, rods, pistons and I'm set, but the reality of it is once you jump in, you start going overboard, you need support equipment, you decide you want to do things a little different, do things the right way", and it adds up quick!
I don't really have the valvetrain stuff up there, I haven't updated it since I talked to Phil last, but I'm running Comp 977 springs and Titanium retainers
I'll have to update that list, thanks for making me get on it.
06-30-2004, 01:55 PM
Premium Member
383.
LE2 cam
LE2 heads
Scat crank
SRP pistons
Eagle H rods
426rwhp...still tuning.
06-30-2004, 02:11 PM
Gripenfelter Can you remove GAIN
Could you please remove GAIN installer from your homepage. IMO worst piece of adware / spyware out there. Looks like you got a nice page but GAIN made me run like the wind.
__________________
LT1 in a 944 The Ultimate Porsche Upgrade
OBDI, CC 306, 1.6, 52mm TB, CC Conical Springs, CNC Ported Heads, ICP Hand Ported Intake, Motec Cold Air, Ron Davis Cooling, Fidanza Alumimum Flywheel, 32# Acell, 390 LPH Motec Pump, Nitrous Express Wet 150, 0-60 3.6, 60-0 91 Ft., www.motorsportranch.com
"Pimpin ain't easy, but it sure is fun!" Seek And Ye Shall Find
06-30-2004, 03:13 PM
4 bolt main bored .040 over, Lunati Forged rods 5.85, Ross custom pistons, Total seal gabless rings, Fed mogul coated bearings, melling high volume oil pump, milled LT1 heads 2.00/1.56 flow close to 280cfm, ported intake, hydra rev kit, custom grind cam 23X/24X 110 LSA, 1.6 RR, 941 springs, comp R lifters, chrome moly pushrods, AS&M 58mm TB, 30# inj, 255 walbro pump, canton race fuel filter, no numbers but I trap on a street tire around 117-118mph 1300 elevation on a 3.23 M6 M29 tranny.
06-30-2004, 03:27 PM
Premium Member
Sorry about Gain. No way to remove it. Its part of Fortunecity.com
You don't need to install Gain and you shouldn't! lol
Just click cancel.
Ignore the dyno video on the page. Thats crank hp from a previous setup.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
