400rwhp n/a, how much spray on stock bottem end?
Old Jun 29, 2004 | 01:15 AM
1982z28with18s's Avatar
I should be right at 400rwhp n/a with my heads/cam setup. See sig for details. I'm looking at high 11.3x's on motor here soon so how much do you think I could spray? I'm thinking a 75 shot just to get in the 10's. I'm a little more worried than the average person since I already have 400rwhp. Any ideas?
Old Jun 29, 2004 | 02:44 AM
QCKZ28's Avatar
i plan to spray 150NX on my heads/cam car in sig later this summer
i will let you know what breaks
jesse
Old Jun 29, 2004 | 02:48 AM
jesse
K, probably will be a rod.
Old Jun 29, 2004 | 02:53 AM
QCKZ28's Avatar
if the rear end doesnt go out 1st
i plan to have a window switch from 3000-6000 rpm
100 octane, and i will dyno it on the spray to make sure the a/f is correct....
i dont plan to spray until 2nd gear....
Old Jul 1, 2004 | 11:02 PM
DrewHMS97SS's Avatar
shoot a 100 shot. just be really carful with the fuel jetting. new fuel pump and all is a must for safty.
Old Jul 6, 2004 | 11:37 AM
slomarao's Avatar
C16 gas. Or the highest thing you can find. You should be ok with a 75. People spray more and get away with it. I would do it on a dyno first and pull more timing. But hitting the juice out of the hole will help your 60ft. big time.
Old Jul 8, 2004 | 12:54 AM
TTT... I'd like to go high 10's on stock bottem end, 10bolt, and 4l60e.
Old Jul 8, 2004 | 03:36 AM
HungryT/A's Avatar
Maybe Derrick can chime in here. He sprays a 175 shot on a Heads/Cam Z with completely stock shortblock.
Old Jul 8, 2004 | 11:04 AM
Z-RATED94's Avatar
Derrick does, or did?
Old Jul 8, 2004 | 12:06 PM
RacinLT1's Avatar
Derrick does,still has the 10 bolt in his car also.
I sprayed 175 pon a stock longblock and went 11.02,woulda gone 10's but the output shaft of the 4l60e didnt agree and broke about 50' off the line.
Old Jul 8, 2004 | 05:40 PM
COMNBYU's Avatar
Werd. There are a lot of guys still running stock sb with n2o. I would say you'd be fine with a 150 or so.
Also, you're NOT going to get into the 10s w/ a 75 shot. Moreover, with 400 on tap NA, you won't even feel the 75 more than likely...
Jon
Old Jul 8, 2004 | 08:52 PM
he would def feel a 75 shot. 400 is a lot out of a stock setup. i dont think i would push 150. maybe if he had done rod bolts.
Old Jul 8, 2004 | 11:50 PM
Jon
You don't think a 75 shot would net me 10's? I'm planning on running low 11.3x's on motor.
Old Jul 8, 2004 | 11:53 PM
most ppl i have heard of drop about a second on a 100. so yes 75 shoud do a 10 if you are 11.3 on motor
Old Jul 9, 2004 | 12:00 AM
It better get me 10's. I don't see me having a problem hitting 11.3x on motor with decent weather and the little mods I have coming up.
