Dual Stage ?
Old Jun 19, 2004 | 02:04 PM
30thCamaroZ's Avatar
Dual Stage ?
I have some of the big NOS solenoids good to a 300 shot. I was wondering if I can make a dual stage setup just using the two solenoids with a y fitting right off of each solenoid? I hope this makes sense. I am using the compucar plate kit and traded those smaller solenoids for these two big ones and would like to continue using the plate kit and then use a nozzle somewhere else. Thanks
Old Jun 20, 2004 | 12:19 AM
speedmiser's Avatar
Nope, sorry, you cant do that. Your going to need seperate solenoids for each stage.
Actually, in thoery you could do it with the right valves/actuators, but it would end up costing much more that just buying the standard nitrous solenoids.
You might also need to look into your nitrous bottle valve flow and the feed line you are using from the bottle - will they both handle a 300 shot? You may have to go to a highflow bottle valve and/or a 6an feed line, then split to 4an's before your solenoids. (or run 2 bottles and 2 4an feed lines - or 2 bottles y'd to 6an feed)
But I'm not really sure at what point you need to step up to 6an - anybody here know?
Old Jun 20, 2004 | 02:39 AM
I already have two ten pound bottles and two 4an feed lines. I have the Power shot solenoids and the cheater so I guess I will just use all 4 and buy another purge.
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
