TNT plate does not fit!
Old Jun 19, 2004 | 12:39 AM
94-3.4's Avatar
Angry TNT plate does not fit!
Can someone explain to me why there is about an 1/8 gap on either side of my TNT plate when i try to mount it up? The nozzles are too fat and won't clear when snugged up into the plate and I don't want to have them almost totally loose to make it fit right. Any suggestions?
Old Jun 19, 2004 | 10:23 AM
LSUxBlake's Avatar
I've never used the plate, but it sounds like you might have the nozzles turned the wrong way. Can you rotate them and make it fit somehow? And are the actual holes on the nozzle facing the TB?
Old Jun 19, 2004 | 11:48 AM
94-3.4's Avatar
The nozzles were in the right direction. If I unscrewed them almost all the way it just about fits but still not right. It is like the nozzles are just too wide or the plate is machined improperly. I might be able to teflon tape the threads and screw the nozzles in just a little bit but then they won't be sticking down in the tb very far.
Old Jun 21, 2004 | 02:18 PM
1994CamaroZ28's Avatar
http://z28camaro.ok-speed.com/nit3.jpg
is mine,
the plate was a pain,
if the pic dont help email or pm me ill help ya troubleshoot
ty_atkinson@***.net
beerboy311 aim
Old Jun 21, 2004 | 06:32 PM
eric9c1's Avatar
You remembered to put a TB gasket on before the plate, and between the TB and intake too right?
I don't know what to say, mine fit fine but I had to get different (longer) bolts
camaroguy50613
May 27, 2016 09:00 AM
Jun 6, 2015 08:27 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
