Blew engine, What would be a good 383 set up for 8psi?
Old Jun 7, 2004 | 09:10 PM
xtremetrans's Avatar
I have an 8 psi pro charger with 42# injectors. What cam should I use, cc305? Any thing I should look out for. and who has the best price on a stoker kit? I think I am going to go with about 9:1 compression.
Old Jun 7, 2004 | 09:38 PM
Mystic95Z's Avatar
A cc305 is not an ideal blower cam. Unless you already have it and dont want to spend the $$$ on a different one, I'd definatly spend the money on a custom grind blower cam. Can the Pro Charger you have make more than 8psi? With a 9:1 motor you'd be able to crank the boost up a bit more than 8psi safely.
-Tony
LukeZ28's Avatar
check out
http://gofaststuff.com/index.html
they also sell parts on ebay
http://www.cmotorsports.com
Old Jun 8, 2004 | 12:09 PM
RealQuick's Avatar
If you need to pass emissions, a few prominet board members here recommend a custom grind 214/224 114 LSA .565/.605 lift (#'s are w/1.6rr's.)
Old Jun 9, 2004 | 08:16 PM
Do I have to do anything to the harmonic balancer? I was also thiking of gettig an aftermarket balancer.
deadmanrunning
Jan 3, 2015 01:12 PM
Jazsun
Dec 29, 2014 12:14 PM
nballisru
Dec 14, 2014 05:01 PM
