1/4 mile times , is this good? (cammed LT-1)
Old May 29, 2004 | 03:05 AM
ram air camaro's Avatar
Hi i went TO the track yesterday and ran these times bellow with my 230/236 cam,3000-3500 converter, pcm tuning, ET STREET'S, and a bunch of other bolton's. i think they suck i feel like i have no topend!!!!
my best run of the day
RT .674
60' 2.067
330 5.740
1/8 8.747
MPH 82.19
1000 11.332
1/4 13.523
MPH 100.82
MY OTHER RUN WAS PRETTY IDENTICAL BUT WITH A 2.1 60 AND A 103.5 MPH!
WHAT DO YOU GUY'S THINK? I'M STILL NOT HAPPY
Old May 29, 2004 | 08:18 AM
DarkHorse's Avatar
I ran the times in sig pre-cam, your runs seem low to me when compared to mine.
Rockers too tight perhaps?
13.600 @100.68 with cai,cat-back, converter 3.42's and drag radials
Have since added the cam valvetrain and headers
Old May 29, 2004 | 09:56 AM
rock1501's Avatar
Ouch and I thought my mph was low for a cammed LT1.
make sure you do the usual checks.check for arcing plug wire,fuel pressure and get someone to scan it.I find most of the time it is something small like a fuel filter of something.
Old May 29, 2004 | 10:44 AM
MBonZ28's Avatar
is the cam your only mod? what were track temps? I used to run 106mph with a stock cam
Old May 29, 2004 | 02:18 PM
track temp around 60's
i got the usual mods headers,intake,exhaust or cutout, etc but cam and 1.6 rockers are the biggest mods i have.
Old May 29, 2004 | 05:48 PM
MBonZ28's Avatar
who tuned it? was it dynoed? do you have some numbers?
I would start checking all the basics too
Old May 29, 2004 | 07:15 PM
transamtom's Avatar
What is the tracks elevation?
Old May 29, 2004 | 09:21 PM
Antz97ZNJ's Avatar
If you have bolt ons w/ that stall n cam you should atleast be in the mid 12's around 105-107 mph's
Old May 30, 2004 | 12:01 AM
i'll be checking for fuel pressure and other small things.
TRACK INFO:
Elevation & General Data
MSL: Approximately 635' 194m (estimated)
Lat/Long: 35.5966219 - 119.1276042 (estimated)
Track Length: 1/4 mile
Run Off Length: 1/4 mile
Parking Area: A whole bunch
Pit Area: 60 + acres
Maximum Seating: 8000
Old May 30, 2004 | 12:52 AM
neil350's Avatar
Ouch man, some thing is deff not right. Your best MPH is that of a average bolt on car. I think the fact your not feelinga top end may have some thing to do with it. Your sixtys also are slow for ET streets and that big of stall.
Old May 30, 2004 | 12:32 PM
HungryT/A's Avatar
That's definiately bolt on, stock engine territory...
Log your runs with a scan tool!
Old May 30, 2004 | 06:27 PM
transamtom's Avatar
Well its not the altitude.
What was the Temperature,Humidity and Barometer reading?
It could have been air quality,what did you run before the cam?
Old May 30, 2004 | 07:37 PM
Kreinmc's Avatar
If I trapped 100 with boltons I would be pissed!
Old May 30, 2004 | 10:03 PM
Daryn95Z's Avatar
I get my car in the high 12's @ 110 with shorties and the 224/230.
I would for sure check the fuel and ignition systems.
Old May 30, 2004 | 10:46 PM
formula383's Avatar
Something is definitely wrong. I pulled a 13.5 @ 100 with a gear, CAI, and shorties. Like someone else said check the basics and go from there with it.
What kind of converter are you running? A 2.0 sixty foot on ET Streets is a very bad problem.
Good Luck getting it sorted out. Thats goes with racing I guess, I still haven't made a trip to the track since the cam that I have been satisfied with.
