Contact list is (sort of) available!
Old Sep 20, 2002 | 09:01 PM
PurpleHaze95's Avatar
OK, I put the contact info from this thread into a nice database so it would be searchable. The problem? I use Lotus Approach and after I had put the whole thing together I discovered that I couldn't save it as a file for MS Access! So it's available as three file types:
an .APR file, which is for Lotus Approach
a .XLS file, which is MS Excel
a .TXT file, which opens right in your browser or can be opened in Notepad
If you discover that your contact information is incorrect, please change your name or your email so I don't have to redo anything.
Old Sep 21, 2002 | 11:45 AM
Grover's Avatar
You should be able to import the Excel file into a table into Access and then create forms and reports to be able to search the data.
Old Sep 22, 2002 | 09:26 PM
I can't figure out how to make Access (I'm currently running Office 97) do that, it's not a menu option that I can find. (Although I confess I didn't spend ages looking either.) So if you know how then be my guest.
Old Sep 22, 2002 | 10:16 PM
DJCobol's Avatar
Access database
There is the Excel Spreadsheet imported into a simple table in Access. If anyone else wants to expand on that by adding more tables or making it into a webpage, be my guest.
Old Oct 2, 2002 | 07:38 AM
Grover's Avatar
What version of Access did you use Chris?
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
ChrisFrez
Mar 17, 2015 07:31 AM
squarehead
Jan 15, 2015 07:02 PM
