electric cut out
Old Sep 20, 2002 | 05:35 PM
housh's Avatar
Angry electric cut out
WTF? I know there is info here about an electric cut out install. I have searched and nothing. can someone point me in the right direction??
Old Sep 20, 2002 | 06:21 PM
2001NBMZ28's Avatar
What do you need? Routing the wires, power connections, ...I installed my QTP electric cut out a couple weeks ago.
Old Sep 20, 2002 | 06:32 PM
housh's Avatar
I am wondering where to route the wire. I hear there is a hole near the right rear seat? If so how do I Identify the hole. I imagine I would have to pull the carpet up then into the center console?
Thanks,
Jeffrey
Old Sep 20, 2002 | 06:40 PM
2001NBMZ28's Avatar
There's a rubber drain plug in the bottom of the seat pan. I cut an "X" and inserted the wire there. One bolt removes the bottom cushion. Then route the wire under the console (just loosen the 4 bolts and tuck it under). I used the black wire from the cig lighter for ground, then ran an extended wire under the dash to the 15 amp radio fuse inside the car. I bought a convertible bezel switch from my dealer and mounted the switch there. Hope this helps.
Mar 13, 2016 03:37 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
rideordie
Sep 7, 2015 08:22 AM
