Cam packages & pricing
Old May 19, 2004 | 10:45 AM
Omega9's Avatar
Question Cam packages & pricing
I was comparing cam package prices with Texas Speed & Performance, and Thunder Racing. Texas Speed's prices are a lot cheaper, and seem to come with better parts.
Pack 1.Your choice of TSP custom-grind camshaft, Comp Cams 26918-16 valve springs good to .600" lift, Texas Speed & Performance hardened pushrods $559.99
Pack 2.Your choice of TSP camshaft, Manley valve springs good to .600" lift, Manley titanium retainers, Texas Speed & Performance hardened pushrods $599.99
Pack 3.Your choice of TSP camshaft, Manley valve springs good to .600" lift, Manley titanium retainers, Texas Speed & Performance hardened pushrods $659.99
Pack 4.Texas Speed TSP Camshaft, Crane Double Valve Springs, Titanium Retainers, Hardened Spring Seats, GM Valve Seals, Texas Speed & Performance Hardened Pushrods $669.99
The TSP cam that I was looking at has the following specs: TSP Custom 224 Cam: 224/224, .566"/.566", 112 LSA
Description: 1700-6500 RPM Power Band; This cam has great mid-range and top-end power with less lift and less aggressive lobes than the 224R. Custom tuning required on automatic cars.
The Thunder Racing cam package is as follows:
Thunder Racing LS1 Cam Swap Package Includes:
- Your Choice of Thunder Racing Custom Grind Camshaft
- Comp Cams 26918 Valve Springs
- Comp Cams 772 Titanium Retainers ($100 Additional)
- Thunder Racing Stock Length Pushrods (7.400)
- Cam Swap Gasket Kit (Specify Year of Car) $699.99
The TR cam I was thinking about getting has the following specs: 224/224 .563/.563 112 LSA
Would there be any difference between these cams?
TSP: 224/224, .566"/.566", 112 LSA
TR:224/224 .563/.563 112 LSA
What do you guys think?
Old May 19, 2004 | 12:48 PM
PhantomTA's Avatar
Re: Cam packages & pricing
If they are both comps, they are the exact same cam.
Its much easier for a shop to advertise that they have their own cams and chance the specs just slightly to make it seem like it.
Just like all those g5 or whatever cams... they are all extreme comp grinds of some sort.
Old May 21, 2004 | 01:44 AM
93TAWicked1's Avatar
Can't go wrong with any of those. Although I'd look into a hot cam kit as a comparison to that 224. IMHO the hotcam kit is so cheap that whatever differences they have you can put into other parts of the car, or finish off all the bolt ons. There are many 390rwhp hotcam cars.
If your going to buy a larger cam I'd go with Futral Motorsport F11 the lobes are actually MORE agressing than the XER which I believe those 224's are although with that low of lift I'm not sure. But the F11 228/230 Is a very good all around cam.
B
Old May 21, 2004 | 05:35 PM
mrr23's Avatar
the 047 cam is one of the best cams i''ve seen gain wise. http://www.vincihighperformance.com/...%20LS1%202.htm
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
