1/2 sec for $300
Old May 17, 2004 | 11:41 AM
jeepz28's Avatar
1/2 sec for $300
how to drop 5 tenths or moer for about $300 so far my mods are moser 12bolt with 4.10's
slp loudmouth
spec stage 4 clutch
and 315/35 drag radials
Old May 17, 2004 | 08:19 PM
simple's Avatar
DIY nitrous
or some real drag tires 16" or smaller with wrinkle wall
Old May 17, 2004 | 10:47 PM
Zigroid's Avatar
get a used CAI off ebay, cut out some weight, perhaps a pcm tune.
5/10ths is alot, $300 is a little.
race when its cooler out?
Old May 18, 2004 | 07:39 AM
Stephen 87 IROC's Avatar
Remove 500 pounds from the car. Cost = $0
Old May 18, 2004 | 08:14 AM
simple's Avatar
lol or you could do that
Old May 18, 2004 | 02:11 PM
soontobeGN's Avatar
if your fat could diet?
Old May 18, 2004 | 03:58 PM
meengreen 94z's Avatar
Re: 1/2 sec for $300
slp loudmouth
spec stage 4 clutch
I know this doesnt have anything to do with your thread, but how is the driveability of the Spec stage 4 clutch? Ive gone through 4 clutches in a little over a year and half and Im looking for something a little more permanent. The car is my daily driver which is why Im asking. Is the clutch basically engaged or disengaged or does it have some slippage?
Old May 19, 2004 | 08:13 PM
Derrick Redd's Avatar
Originally posted by simple
[B]DIY nitrous
Ditto.
Old May 19, 2004 | 10:50 PM
hsyr's Avatar
Re: Re: 1/2 sec for $300
From what I understand the stage IV drives exactly the same as the stage III. Considering that the disc is identical other than one is a sprung hub and the other is solid I would imagine it would be close. I will find out next week since my stage III disc is shot and im putting in a stage IV disc. Don't expect ALOT of miles out of it tho. I think I got 15-20,000 miles on my stage III and its slipping now. But atleast it will still drive when it slips. I think the IV will be very easy in day to day driving. My stage III was anyway. Hope this helps.
Old May 21, 2004 | 12:01 AM
Jay-Roll's Avatar
I bet that's a lot easier said than done. I can only think of enough stuff to remove that'll equal only about 100lbs. Have no idea where 400 more lbs would come from lol. Getting the CAI or making your own for around $35 bucks or so and trying to get nitrous is probably your best bet. Stickier tires if you can't get the DR's to hook. Some ET streets or maybe drags would cost about that much and allow higher rpm launches and could get you .2-.3 tenths atleast.
Old May 21, 2004 | 01:32 AM
jeepz28's Avatar
thinks for all your replys
the stage 4 clutch is streetable just getting a little use to
blac94Z
Nov 4, 2015 01:59 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
CARiD
Sep 7, 2015 08:21 AM
