900hp 2600lb race car for sale or trade. Rolling, turnkey or parts
Old May 16, 2004 | 09:27 PM
Timberwolf's Avatar
1975 Chevy Camaro
Engine: 408 Ci, 40 over 400. splayed 4 bolt mains, poured with rock block (half),
steel crank, Eagle rods, Wiseco pistons, moly rings, solid roller Reed cam
Duration at .050 is 262/267 ADV Duration: IN 296 degrees, exhaust: 302
degrees. Lobe Lift: IN .412" EX .417" Vavle Lift: IN .618" EX .625" @1.5 roller rockers. Valve Setting: IN .020" EX .022, zero decked block, Brodix Track I heads, 2.08 intake, 1.65 exhaust, intake runners 215 cc, triple valve springs, compression ratio 13.2 to 1, receiver grooved heads, block wire head gaskets, head studs, Brodix HVH intake plumbed with direct port fogger nitrous system, 825 Race Demon carb.
Fuel System: Mallory 140gph electric fuel pump, 15 gallon fuel cell
Exhaust: Hooker 2 inch longtube headers, 3 inch X pipe with Flowmasters, pipes exit behind the tires.
Transmission: Turbo 350 trans. with reverse valve body and trans brake, 4400
stall converter, B&M shifter.
Rearend: Brand new Ford 9inch style, Strange Nodular case, Moser axles, 4.11 pro gear ring and pinion with full spool, daytona pinion support, 1350 billet yoke, housing back brace, disc brakes, southside traction bars.
Ignition System: MSD ignition, 7AL-2 with two-step, with rev. limiter pills.
Body & Chassis: Sub frame connectors, drive shaft loop, Vega steering box, aluminum dash, race driver's seat with harness, 8 point cage, fiberglass 1970-73 style front clip, 'glass 6" cowl hood, 'glass rear bumper, 'glass decklid and 'glass doors (all fiberglass is brand new and ready to be installed). Ready for lexan windows. Body is channeled for ladder bar or 4 link.
Wheels & Tires: Centerline Autodrag wheels. Skinnies in the front, 28x12.50 ET streets out back.
Car Weight: estimated at 2600 lbs. (without the driver)
Car is mean and nasty. 600hp on motor, plumbed for 300hp nitrous shot. Needs a little finishing, but it could be on the track with a week's work or so. Car ran high 6's in the 1/8 (approx equivalent mid 10s in 1/4) on motor only weighing 500lbs more and with restrictive intake and carb. Should be easy 10 flat once tuned. Add 300 shot to that and hang on tight.
I'll sell the whole works for $9000 or may seperate big components (engine, trans, rear end, chassis). Only reason for selling is I am tired of throwing all my money into building a killer race car and having my daily driver's fall apart around me. I need a DEPENDABLE, decent MPG (20mpg or better) daily driver. So if you have an interesting trade offer for all or part of this car, let me know.
Email me at timberwolf@michiganspeed.com
Old May 16, 2004 | 09:56 PM
ws6transam's Avatar
Don't do it, Mike----
See it through! It it's the LS1 installation that's bugging you, let me know if I can help!
Is it just because you need a regular ol' dependamobile?
Surely we can find you an Achieva or something unremakably dependable for cheep- - - No need to cash in the race parts.
Old May 16, 2004 | 09:59 PM
Timberwolf's Avatar
Problem is I am outta cash Dan. I gotta get the ls1 installed asap. probably going to attack that this week sometime. In the meantime I am running 120 miles a day commute at 10-12mpg, and the wife is driving a borrowed vehicle.
Old May 16, 2004 | 10:11 PM
ws6transam's Avatar
Put the LS1 on the trailer and bring it over if you need the garage space, Mike. I have the room at the moment, and I have the engine hoist. I could probably put in a few hours in the evenings on it for you as well, assuming you help me with my Minirammed 385 when it's ready for bolting in ??
Old May 16, 2004 | 10:16 PM
Timberwolf's Avatar
Might take you up on that dan, we'll see. It should only take a day realistically. As long as we can remember where everything plugs in It's been out isnce November or so. I have a converter here for it and some long tube headers. those are easy to install since the engine and trans are both out. Then the car just sits down over the top of the whole shebang.
Old May 17, 2004 | 07:15 AM
donZ's Avatar
how much for just the motor ?
Old May 17, 2004 | 07:57 AM
Timberwolf's Avatar
I'd probably take $4500 for the motor. Trades considered as usual
Old May 17, 2004 | 09:23 AM
TrouserSnake's Avatar
Wheres the pics?
Old May 17, 2004 | 12:24 PM
Timberwolf's Avatar
forgot to mention a few things:
Engine has SFI fluidamper and SFI flywheel.
Igntion has MSD Pro Billet distributor and Taylor 409 wires. Also has the MSD Pro blaster coil.
Fuel system has a regulator with dual output, restrictor and fuel pressure gauge, and aluminum fuel line from the fuel cell to the reg, braided line from there.
I can take pics of whatever you want to see for people seriously interested.
Old May 18, 2004 | 02:55 PM
Timberwolf's Avatar
Someone want to trade me a motorcycle?
Old May 18, 2004 | 11:16 PM
ws6transam's Avatar
DARN! I just got rid of mine!
Joes96z
Dec 14, 2014 04:03 PM
Queens94z28
Nov 20, 2014 06:03 PM
00WS6mike
Sep 13, 2002 10:37 PM
Carguy00
Aug 6, 2002 10:25 PM
JasonD
Jul 15, 2002 02:17 PM
