Difference between the Z28 and SS?
Old May 8, 2004 | 10:11 AM
Grave's Avatar
I'm doing some research on Camaros, and I wanted to know all the differences between a Z28 and an SS?
So far I know the SS models have the ram air setup, rear spoiler and the SLP exhaust and suspension.
Anything else I'm missing?
Old May 8, 2004 | 10:19 AM
Lt1 and Ls1's Avatar
Not that I can think of. I think they have different exhaust. The ss has duals right guys?
Old May 8, 2004 | 10:30 AM
MasterEvilAce's Avatar
the SS was practically ONLY appearance-related items....
you can order additional things for the SS, though.. such as center-mounted exhaust, Auburn differential (i think it was), and in 2002 (last year) you could get a performance upgrade.. which increased the car to 245HP, i believe.. it was basically a LID, and i think a catback, maybe one other thing or something, I don't know
Old May 8, 2004 | 10:41 AM
LqMth's Avatar
245hp....hmmmm??
Old May 8, 2004 | 10:47 AM
mikes99ssuper's Avatar
might be obvious but they had 17" rims and tires too
Old May 8, 2004 | 01:14 PM
Originally posted by LqMth
245hp....hmmmm??
sorry, i'm an idiot.. 345
Old May 8, 2004 | 09:45 PM
99blackSS's Avatar
The ones that have more then just bigger sway bars handle quite a bit better then an average Z28.
Old May 8, 2004 | 09:51 PM
96SSConv#2033's Avatar
Mine has:
Cold Air hood
Rear Decklid spoiler
16" ZR-1 style cast aluminum alloy wheels
16" BF Goodrich Comp T/A tires
2 OTL exhaust
Torsen Limited Slip Diff
Hurst Six speed short throw shifter
High flow exhaust manifolds.
Synthetic lube package: Synthetic oil, rear axel lube and semi-synthetic power steering fluid.
Oil cooler
SS emblems replaces Z28 tags.
2 numbered keychains and 1 numbered dash plaque.
The 17" rims and Bilstein suspension is only available on coupes and T-tops.
Old May 10, 2004 | 06:10 AM
Grave's Avatar
Sweet... thanks for the info fellas!
What's a LID?
If I think of something else to ask, I will.
Old May 10, 2004 | 08:35 AM
ppmz28's Avatar
it's the LS-1 stock air box...... they have better flowing ones....basically a better lid
Old May 10, 2004 | 10:55 PM
MrDino's Avatar
Hope this isn't thread jacking, it's semi related...
If your planning on putting on a cold air system, and a higher flowing exhaust system (seems that this is what gives most SS's higher hp ratings) anyways, wouldnt a regular z28 be a good/cheaper platform to get about the same kind of power from?(minusing the appearance/cool factor of course)
Old May 11, 2004 | 03:59 AM
99blackSS's Avatar
Minus the suspension too, but yes, there is not much difference hp wise.
I believe the LT1 Z28s and SSs had a bigger hp gap then the LS1 versions.
Old May 11, 2004 | 05:47 PM
GoFast908Z's Avatar
Member
Originally posted by 96SSConv#2033
Mine has:
16"??? where did you get those. I've seen only one set of those ever.
17" only on coupe and t-top? I don't think so. SS has 17" on all models i've seen, including convertables.
Old May 11, 2004 | 07:20 PM
Ok, here is a direct quote from the window SS part of the window sticker:
16"x8.0" ZR-1 Style Cast Aluminum Alloy Wheels
The one page front and back brochure says 17" with a * that says "Convertible models retain stock Camaro Z28 suspension, receive 16" version of BFGoodrich Comp T/A tires and receive 16" x 8" ZR-1 styled cast aluminum alloy wheels."
If my scanner was working I would scan it for you.
Here is a link to the SLP website with the exact same rims that I have:
http://www.slponline.com/view_produc...&SHOWEMAIL=Off
I have a '96. '97 and newer may have had the upgraded suspension and bigger wheels.
Old May 11, 2004 | 09:10 PM
JeffK's Avatar
On 96-97 SS's all converts got the 16" ZR1 wheels. SLP put them on there for a better ride quality (or so they told me). All other hardtops and T-tops got the 17" units.
When GM had more to do with the SS in 98, all SS's came with 17" wheels.
Also 96-97 SS's had a polished lip on the rim. I don't recall seeing anything from 98 on with that. Correct me if I am wrong.
